Vizio E552VLE Not Turning On
  • Agent24
    I see dead caps
    • Oct 2007
    • 4977
    • New Zealand
    #41
    Re: Vizio E552VLE Not Turning On
    Should be fine, I do that kind of thing all the time, although it's better if you have alligator clip leads to connect to the paperclip etc, less chance of slipping etc.
    -David VanHorn
    • TheTesterMan
      • Apr 2015
      • 91
      Was a solution for this issue ever determined ?
      • Roundpen
        • Oct 2016
        • usa
        #43
        Hope this gets to whoever....I have the same model number Vizio, and mine won't turn on...The amber licht at bottom center of frame will go from amber to white, then then the large V on the screen flickers on, then immediately off...???
          You might as well start a new thread and upload good clear pictures of the boards and the whole back side of the TV. I hope you can at least know how to use the meter.
          • RRice25541
            • Nov 2015
            • 47
            hey everyone, I've got this PS with a totally different issue.
            I tried to post a new thread on this but it wouldn't let.
            anywho, here's the issue i have..with the PS unhooked from the rest of the set
            I've got 5Vstby, but when i jump from there to the PS_ON the 12v,24v and the 18V supply lines quickly jump up to around there normal voltage range, and then drop to zero gradually..like caps draining off.
            I'm wondering if IC900 is the problem SG6742MR
            anyone have any idea's i've checked and rechecked every part on this PS and can't find a single part shorted or open
            • RRice25541
              • Nov 2015
              • 47
              sorry i shoulda mentioned the PS was DPS-321AP. my bad :-)
              • Arkiered
                Vizio E552VLE Main Board
                by Arkiered
                Hi everyone, I am looking for a schematic diagram for the Main Board to a Vizio E552VLE. I have 5V Stby good and solid, but I get no Pwr On signal. If I jumper 5V to it, the Power Supply has 12 and 24V, but I also get no signal to turn the backlights on. Any help is appreciated, Thanks.
                10-23-2022, 05:43 PM
              • mrtek
                Vizio M65-C1
                by mrtek
                Hi.
                picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                07-14-2025, 07:28 PM
              • SS454
                vizio e650i-a2 backlight flashes then turns off
                by SS454
                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                panel: au optronics T650HVN05.4
                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                08-20-2020, 03:57 PM
              • Holes Flow
                Vizio E552VLE Schematics needed! [no power on]
                by Holes Flow
                Experts,
                Like other posters, I cannot get this behemoth to turn on, nor does the Vizio "off light" illuminate. Bought anther power board-no change.
                I have no voltages on any of the connectors where voltage levels are indicated. I have voltage on one side of the isolation transformer, and nothing on the other side-on both boards.
                Its becoming obvious that the controller board needs power to send a signal back to the power board, but no juice at ALL gets to the control board. REALLY need a schematic...
                trying this way... vBulletin can...
                08-27-2022, 03:40 PM
              • pedromvu
                Vizio M65-E0 not turning on
                by pedromvu
                Hi, I know these TVs are common to have problems like this, but unfortunately I was not able to find repair guide for this specific model or for something with this kind of power board.
                The thing is this doesn't have the 5vsb pin which is used to determine from which board the issue comes.
                Everything in power and main board was inspected without any apparent problems, but haven't measured everything.
                The voltages from Power to Main board are as follows:
                NC = 0
                A = 0
                BL_on/off = (Some millivolts, probably considered 0)...
                11-18-2022, 12:28 PM
