Black point of the multimeter connected to the chassis of the tv and taking measure with the red point on FAN7530, all pins read less than 0.1v
OK, you are making Voltage measurement in the primary side of the circuit so you have to use the negative leg of the main filter cap as the ground ref point for the meter.
Please make the DC voltage measurement of all the pin of FAN7530.
Then check the resistance between the Ground pin against all the other pin and report the resistance readings, please make sure to report if the reading is in Ohm, K Ohm, or M Ohm.
