Sharp LC-52LE640U Bad Panel?
  • Baldrick
    • Apr 2014
    • 19
    I've got a Sharp LC-52LE640U that flashes 5 fast/2 slow. I've finally gotten half of the screen to work perfectly.
    When I disconnected the two ribbon cables from the t-con board to the panel, the blinking stopped. I then plugged one cable back in and I got half the screen working great, but the other half is white. When I plug the other one in, it dies and I get the error again.
    Is this definitely a bad LCD panel? Is it worth even thinking about repairing it?
    Thanks.
  • nuala
    • Aug 2013
    • 37
    Re: Sharp LC-52LE640U Bad Panel?
    12v panel fail is usually either no 12v to tcon or a blown tcon fuse, the voltages look good.
    • splitcrete
      • Dec 2012
      • 387
      • usa
      Try flexing the panel to see if it gets better,or use a hair dryer blown to the t-con ribbon cables. I sounds like a tab bond problem..
      • tibimakai
        • Jan 2012
        • 3680
        I would look at the tabs, to see if there is any damage there(not tab bonding).
        I have a Sony, which had the same symptom and I have found blown tab and panel board in the same spot where they touched each other.
          If 15V to one of the panel sides is shorted, it could cause a 5-2 code. Bad panel... Maybe worth checking for shorted MLCC on panel which might be fixable.
          • Baldrick
            • Apr 2014
            • 19
            Well, something's changed... Now, I no longer have the 5/2 blinks. With the one ribbon cable plugged in, I have the left half of the screen working great. When I plug the second cable in, I get an image on both sides, but the whole screen is faint, flickering, and blotchy.
            I noticed too, the when the second cable is plugged in, I get a slight buzz from the tcon board.
            tom66, would the MLCC you mention be on the driver board?
            Thanks.
              If by driver you mean the long PCB which extends along the top of the panel, yes.
              • advant
                by advant
                02-03-2020, 12:25 AM
              • kca
                by kca
                Hello all ~
                08-31-2025, 06:38 AM
              • netgearnetgear
                TCL 43S423 TCON OR PANEL FAULTY???
                by netgearnetgear
                Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                08-20-2025, 06:04 PM
              • howardc64
                Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                by howardc64
                Failure Symptom
                No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                Where is the short?
                Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                05-27-2025, 02:56 PM
              • rimwall
                Sony KD-65x7500D - double image - Tcon or Panel?
                by rimwall
                This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                11-18-2025, 02:09 AM
