Panasonic TH-L32C30Z troubleshooting
  • Ragga_NZ
    • Oct 2014
    • 4
    • New Zealand
    I was wondering whether someone could help me troubleshoot my panasonic tv. TH-L32C30Z.
    The initial problem was the tv would turn itself off (to standby) about 10 minutes after viewing (continuous flashing of red LED, no
    pattern). Then after a while it would do this after a few seconds after it was turned on.
    I used a remote control and lower volume button on the set to do a factory reset. No it turns on, shows the setup page screen goes
    dark, setup page comes on again and screen goes dark again, setup page comes on again and then goes dark and stays that way (green led
    stays on). Whilst this is happening I can hear buzzing initially from the square transformer at the top of the p board and just before
    the screen goes dark a buzzing sound from the top transformer with the two windings. Can't see any bulging or leaking caps. Any ideas????
    Thanks very much for your help
    Two vids at
    https://www.youtube.com/watch?v=L2YKdowUydk
    https://www.youtube.com/watch?v=s70p9ft-vX8
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic TH-L32C30Z troubleshooting
    Could you post some pictures of the boards?
    • Neelix
      • Oct 2013
      • 145
      • South Africa
      Post some pictures yes, but I think it's a backlight or inverter fault
      • Ragga_NZ
        • Oct 2014
        • 4
        • New Zealand
        Here are pics of the p. board and the components that are buzzing on the P. board. I haven't got a pic of the other board at present will need to open up when i'm at home.
        • tw2005
          • Oct 2011
          • 6458
          These are ideally what people like to see to help.
          It's the US version CA, minor differences(caps)
          Fitted to TC-32LX34 TC-L3232C TC-L32C3 TC-L32U3 TC-L32X30, could try searching the models or board version and see if any faults have been reported here?
          Yours is TNPA5361AA, I saw one in malaysia but not cheap on Ebay,
          I had a tiny 19" and it continuously blinked green, brief flash of the backlight. had one of the H-FETs shorted and what fixed mine was a new transistor and an Electro Cap known to be bad (jamiecon 85deg, 100uf ?)
          I'm thinking C7513,7514. Q7503,7504(underside) be worth checking.There was no visual indication, just lucky another reader put me on to the cap, was about to bin it.
          Could be the HV caps but I'm out of my area of knowledge really.
          maybe track this thread, Aussie version, pretty sure 1 blink is backlight cct so there maybe a common issue.
          https://www.badcaps.net/forum/showthread.php?t=41593
          • ainsworth
            • Oct 2013
            • 23
            • jamaica
            I have a Panasonic tc-l32u3 I'm getting no display, when I press the power button that's the time the red light comes on and stays on but I see nothing on the screen.
            • ainsworth
              • Oct 2013
              • 23
              • jamaica
              Can anyone help
              • dskall
                • Oct 2016
                • 2905
                • usa
                Need good clear straight on pictures of back of tv with cover off and each board.
                Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
                Format:
                Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
                1 - XXXXXXX - XXv - XXXv
                2 - XXXXXXX - XXXv - XXXv
                3 - XXXXXXX - XXXv - XXXv
                4 - etc.
                • mikey5791
                  Is it possible for transformer substitution?
                  by mikey5791
                  Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                  Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                  My questions are
                  1. How do i test to see if the transformer is in good working condition?
                  2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                  Hope you guys understand what i was asking. My intention is...
                  11-03-2022, 02:11 AM
                • ohren
                  Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                  by ohren
                  Hello!
                  I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                  Measured voltages with no load:
                  After rectifier diodes
                  12V: 6.17 V
                  5V: 5.67 V
                  Secondary transformer pins AC measurement (really don't know if this says anything)
                  12V: 2-2.5 V
                  5V: 1.04 V
                  I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                  03-18-2023, 10:33 AM
                • blues_spirit
                  practical courses for troubleshooting pc motherboards
                  by blues_spirit
                  Hello from France,
                  mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                  Do you think this is feasible for me? I...
                  12-18-2022, 12:56 PM
                • angelos
                  Technics Transformer question.
                  by angelos
                  Hi there,
                  I have this CD player from a Technics Component unit whose mains transformer is blown. The primary winding is open circuit. This transformer has many secondary windings on its secondary side. This transformer is obviously obsolete.
                  I need to know if my trick for a alternative transformer will work. Please check the attachment for explanation.
                  I want to use three separate transformers to be equivalent like the original transformer.
                  The only thing a bit dodgy is the connection of the 9.6V and 12V outputs of which there is a interconnection between the two windings....
                  09-14-2022, 02:14 AM
                • denisten
                  Sony STR-DB870QS standby transformer
                  by denisten
                  Hi everyone, i am a newbie here and i hope i will find the help i need. I have the above mentioned receiver with standby transformer's primary coil damaged. I have searched the net without success to find any tech data about this transformer. I have only the Sony part number1-437-313-11 and TAM Malaysia M0126. I guess i could find replacement for it, but i need to know the secondary coil voltages and VA. It is 220v on the primary. It has 5 pins on the secondary, the outer two are not used and i have 6.5 ohms between pins 2and 4, 3,9 ohms between 2 and 3, and 3,6 ohms between 3 and 4. Can someone...
                  04-14-2023, 03:24 AM
