Panasonic TH-50PZ700U Screen Shorted?
  • Treydogg77
    Treydogg77
    • Mar 2013
    • 99
    • US
    I've got a Panasonic TH-50PZ700U that had the 5 blink error. I replaced the upper buffer board. That didn't change anything so I replaced the Y-sus and and upper buffer board, the screen came up for 2-sec then it shut back down. I removed the upper buffer board, and now the tv comes on with the bottom half of the screen working perfect. So I put the old Y-sus board back In and it works with the lower buffer board, but goes into shut down when I install the upper buffer board. How can I tell if the screen is shorted, and would it short the upper board out?
    Thanks for any help and or advice!
    Re: Panasonic TH-50PZ700U Screen Shorted?
    5 blinks? 7 blinks is more commonly SU/SD/SC board.
    • Shinju
      • Mar 2014
      • 1239
      Well if the screen is working with the lower buffer attached and not the upper I would replace the upper buffer.
      Sounds like the upper buffer has bad IC's on it and needs to be fixed or replaced.
      Also, when replacing those buffer boards, MAKE SURE to get those ribbon cables in correctly they are a PITA and require some patience and need to be put in straight on. You should feel a small click followed by a more aggressive click if set in correctly. (I believe)
      This is where I would start!
      https://www.google.com/?gws_rd=ssl#q...+board&tbm=vid
      • Yanleb
        Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
        by Yanleb
        Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
        I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
        D608, good
        D618 RF101L4S, good (See warning 1 below)
        D619 RF101L4S, good (See warning 1 below)
        D865 RF101L4S, shorted (See warning 1 below)
        IC464 Inverter HA MC74HC1G14, shorted...
        03-09-2020, 12:00 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • reessi
        Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
        by reessi
        Hello:
        I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
        I started on the ACER:
        Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
        All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
        I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
        10-29-2024, 11:31 AM
      • spleenharvester
        Whirlpool PACF212HP W portable air conditioner, upper fan only turns slowly.
        by spleenharvester
        I just acquired this portable aircon, history unknown. Its behaviour is quite strange:
        • When turned on and placed into cooling mode, the upper fan (cold air out) just spins slowly. The compressor and lower fan do not run.
        • If the device is then placed into heating mode and then back into cooling mode, the lower fan and compressor kick in and start cooling, but the upper fan still only spins slowly.
        • If the device is placed into fan-only mode, the upper fan does not respond to low/medium/high speed toggles - just keeps running slowly.
        • Display and buttons all behave normally aside from the
        06-27-2025, 07:49 PM
      • modtool
        HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
        by modtool
        Hi to all,
        the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
        I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
        I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
        04-01-2025, 08:22 AM
