VIZIO VO47L FHDTV10A - Voltage Regulator Input
Re: VIZIO VO47L FHDTV10A - Voltage Regulator Input
Those two fuses on the main board:
One is for 5V, another one is for the switched 12V, so check the fuses as suggested by R_J.Never stop learning
by ugamazingSo, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not... -
Assuming...7 Photos -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by disorderhello,
i have a hp display 2311 to repair, totaly dead
on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
thank you-
- Loading...
