50" Plama vertical lines - repairable??
    Re: 50" Plama vertical lines - repairable??
    The panel in this set is made by Panasonic.
    It could be a digital/control board fault or a main board fault. I am looking at how the glitch changes around the channel/input name in the corner, so I'd suggest the main board could actually be at fault.
    Quite hard to tell on a Panasonic based panel as the OEM'd sets don't have test patterns built in.
    • mmartell
      • Oct 2013
      • 3189
      Hmm looks like you have a Panasonic set with this board or a variation of it:
      http://www.shopjimmy.com/panasonic-t...es-d-board.htm
      $71. Do you have a digital multimeter to check some basic voltages ?
      • Stevie B
        • Oct 2014
        • 32
        Are you referring to the small board behind the main board?
        Is that the control board?
        I didn't catch that tom66 had referred to it.
        Its Maxent MX5020-HPM.
        So you're saying the hidden board is the suspect?
        • Stevie B
          • Oct 2014
          • 32
          Is the link that mmartell posted the main or the control board?
          Is it a good idea to just verify the part number and replace it?
          • Stevie B
            • Oct 2014
            • 32
            I have a fluke for any voltage measurements.
            But I need to get info, I don't have any video electronic experience.
            • freakaftr8
              • Oct 2012
              • 3743
              Freeze spray the 3 16v 220 mfd capacitors to the left of the main processor on the mainboard. See if problem gets better or worse. Then try a lil heat too. Seen this multiple times on this model. Yes it uses panasonic guts. They put out a decent picture
              • mmartell
                • Oct 2013
                • 3189
                Ya sorry, I was suspecting control board, that's the one hidden beneath the main board but tom and freak are much more experts in these matters so definitely follow their recommendations.
                • Stevie B
                  • Oct 2014
                  • 32
                  The main board is out of stock at shop jimmy.
                  The part number is the same except for the suffix. On mine it is ---, the replacement is -1-.
                  I assume its just a newer version of the same part.
                  In the meantime, I'll pick up some freeze spray.
                  What is a good way to apply heat? A hair dryer?
                    Hairdryer works well for the heat.
                    • ademim
                      • Dec 2014
                      • 28
                      • Portugal
                      #30
                      Originally posted by mmartell
                      The last board you uncovered is the digital board and the one tom66 is referring to. I would heed his advice and replace it. I had a similar "interference" problem in a Pioneer plasma which he suggested I replace and it was the problem.
                      Who makes this tv ? You need to get the part number from the control board.
                      it looks like its a panasonic(look at the chip on the board)...
                      • ademim
                        • Dec 2014
                        • 28
                        • Portugal
                        #31
                        hi i also have a very bad problem which i think is the panel itself as you can see in the videos ,its a samsung ps50a451p1 50" plasma.
                        i hope im not doing something wrong by posting my problem here but due to the title i thought it would be a good place.
                        http://youtu.be/omRKU3-Xqkg
                        http://youtu.be/ayNn7tij5Qo
                        • mmartell
                          • Oct 2013
                          • 3189
                          You can see in post #22 where I figured that out about seven minutes after the post you quoted but thanks for the heads up.
                          And start your own thread since it's a different make/model.
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            #33
                            Doesn't mean a thing!--Set makers will use whatever is available and has the features they want.
                            Set I have at the moment has at least two visible Sony chips on its mainboard--yet, the name on the front is--
                            Panasonic.
                            TELEFIX
                              Definitely panel. Your unplugging / plugging in of the Va connector may well have contributed to the demise of the panel. These panels are very sensitive to this.
                              • ademim
                                • Dec 2014
                                • 28
                                • Portugal
                                #35
                                Panasonic.
                                hi again and sorry for butting in with my problem on thius thread i will start my own ,and i know what you are talking about when makers use other brand materials for making lets say a logic board or in cell phones.
                                • Stevie B
                                  • Oct 2014
                                  • 32
                                  So then regarding my issue with trying to get a main board replacement.
                                  At shop jimmy and other sites, when I search for QPWB11578Y1G I get results for YPWB or DPWB instead.
                                  Is this the same thing or do I need to get QPWB specifically?
                                  • nomoresonys
                                    • 12276
                                    • U.S.
                                    #37
                                    is that your model number?, if not try putting your model number in the shopjimmy search if thats where your searching at.
                                    • nomoresonys
                                      • 12276
                                      • U.S.
                                      #38
                                      if its there, it should say what panel numbers it will work with, in the description.
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        I may have this board. Give me a bit to look at it when I get home.
                                        • freakaftr8
                                          • Oct 2012
                                          • 3743
                                          But did you first try the hairdryer method on those electrolytic capacitors on the left of the processor on the mainboard yet?
                                          • Falki
                                            Colorful LCD Vertical Lines on Samsung ue55es8090
                                            by Falki
                                            Hello there, ive recently found an older 55inch Samsung SmartTV.
                                            Sadly it has vertical lines at the left and one line in the middle-right.
                                            I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                                            I have factory resetted the TV as well but also with no luck.
                                            I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                                            A similar issue has been posted as well but also with no actual response ...
                                            08-12-2025, 04:19 AM
                                          • visionbluedemon
                                            Help. Sony kd-65x85dj vertical lines
                                            by visionbluedemon
                                            First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                            Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                            tried blocking LC lines too, but same results
                                            is it lcd panel issue or tcon board issue?...
                                            07-25-2025, 04:56 AM
                                          • gpo23
                                            Sony KDL-40V3000 - Vertical lines
                                            by gpo23
                                            i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                            With the new t-con the color are good but there are vertical lines on all the screen :
                                            I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                            Is there a way to fix the vertical lines on the new t-con ?
                                            Thank you for your help
                                            gpo23...
                                            10-04-2023, 09:11 AM
                                          • Firentiosi
                                            1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                                            by Firentiosi
                                            Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                                            The issues are as follows: the...
                                            11-27-2024, 12:33 AM
                                          • hendue
                                            BenQ 2765HT vertical lines, no picture
                                            by hendue
                                            I was trying to fix the monitor, which was giving me the following pictures:
                                            It was somehow reactive, such that if I pressed the buttons, the lines changed in positions or if i moved e.g. a task window, it would somehow change the patter, too.
                                            I swapped out the mainboard without any luck. So I thought that it has to be an issue with the panel itself and was trying to assess whats wrong on the control board of the panel.
                                            Somehow, I managed to short the LVDS protection with a MOSFETS cooler on the PCB.
                                            I turned around...
                                            09-09-2025, 08:27 AM
