50" Plama vertical lines - repairable??
  • Stevie B
    • Oct 2014
    • 32
    I've been using my Maxent 50" monitor/TV (no tuner) as my computer monitor for about 3 years using an HDMI input.
    It's about about 7 years old.
    Never had any issues - until yesterday.
    I had it on for about 30 minutes (working fine), and it suddenly displayed with multicolored vertical lines across the entire screen, top to bottom.
    I heard no noise when it occurred.
    Same problem exists on all inputs and menu function display.
    The lines are stationary but seem to vary depending on what image is being displayed.
    They are sometimes 2 or 3 or up to 5? pixels wide.
    There appears to be other colored artifacts around certain displays.
    There are no other types of lines.
    The TV has some kind of input selection thing that when no signal is detected it displays solid blue. This still shows up with a solid blue without those lines.
    So I'm thinking it's not the panel???
    Has anyone had experience with this specific issue?
    I'll try and attached a couple of pictures.
    (The horizontal black bars are from the camera phone synch, not visible in real life)
    I've never dealt with TV repair - only tube amplifiers - but now I'm very interested in learning about this stuff
    Any help is appreciated.
    Re: 50" Plama vertical lines - repairable??
    Not panel, looks like digital board. Who made the panel in the TV? Pictures of boards and chassis would help.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Very much doubt its the panel--in fact I would go as far as to say,--No way is it that.
      Possible Control-Board, but I'm thinking more the mainboard....
      Ah--Tube (Valve) Amplifiers--another passion of mine, designed and built quite a few,--Forget everything Valve related when working on Plasma sets--Nothing seems to apply from the dark-arts of Valve technology!
      TELEFIX
      • Stevie B
        • Oct 2014
        • 32
        I believe it is a Maxent MX-5020HPM.
        I haven't opened it yet to see if there are manufacturer's labels, so I don't know who made the panel itself.
        Here is a close up of the lines...
        • Shinju
          • Mar 2014
          • 1239
          You will need to open the panel before anymore troubleshooting can happen. I think Maxent had both Samsung and LG versions if I remember.
          Before buying any parts try cleaning and reseating all of you ribbon cables from your logic/controller board. Once you get some photos of the guts someone can direct you on what you need to do next and what boards you are looking at.
          • Stevie B
            • Oct 2014
            • 32
            After I open it up I'll post pictures of the boards and layout.
            Could it be as simple as the ribbon connectors needing a mechanical refresh?
            I wouldn't call vacuum tube amps "dark-arts"; more like "classic" audio design
            (admittedly much simpler to understand)
            • Stevie B
              • Oct 2014
              • 32
              Thank you all for such great responses.
              Great forum. Great site.
              (Those bad caps infiltrated lots of Fender amps starting about 8 years ago too.)
              I'll try to open it tonight, it's about 100 lbs and it's still up on the wall (I'll need help).
              More pics and posts will happen then.
              • Shinju
                • Mar 2014
                • 1239
                Tom66 has a plasma troubleshooting guide. I would recommend searching for it and do a little reading and see what you are going to be diving into. When you crack that sucker open you are going to be like WOAH!
                These older plasma's have a lot going on inside of them.
                • Stevie B
                  • Oct 2014
                  • 32
                  OK, I'm back after a frenetic "end of year".
                  I have cycled all the physical connections (ribbons/connectors) I could access without board removals, and the set is still with the "noise" symptoms.
                  It exists on all inputs.
                  No real change after the "refresh" but now it seems to have more "movement" - as I recall, the "noise" seemed more stationary before. (could be my memory though)
                  Visual inspection of the installed boards shows nothing that I could see.
                  I pressed several locations on boards and components while viewing the picture's reflection and there was no change.
                  I have several photos to post.
                  • Stevie B
                    • Oct 2014
                    • 32
                    There is a definite pattern in one section of the screen that does not extend all the way to the left
                    • Stevie B
                      • Oct 2014
                      • 32
                      But that pattern temporarily shows up on the right side at start up too...
                      • Stevie B
                        • Oct 2014
                        • 32
                        With an input, the picture has the "noise" across the screen but also has that additional peculiar pattern on the right - and stays there on the right.
                        (I just realized I have my left and right backwards n the previous posts)
                        • Stevie B
                          • Oct 2014
                          • 32
                          Power supply looks fine...
                          • Stevie B
                            • Oct 2014
                            • 32
                            Main board looks fine...
                            • Stevie B
                              • Oct 2014
                              • 32
                              Left and right sus boards look fine
                              • Stevie B
                                • Oct 2014
                                • 32
                                Top and bottom look good
                                • Stevie B
                                  • Oct 2014
                                  • 32
                                  bottom left
                                  • Stevie B
                                    • Oct 2014
                                    • 32
                                    There's a small board behind the main board that I didn't get to see without disassembly
                                    • Stevie B
                                      • Oct 2014
                                      • 32
                                      I'm looking for someone who can suggest which boards to replace - or let me know that it may be cheaper to buy a new 50".
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        The last board you uncovered is the digital board and the one tom66 is referring to. I would heed his advice and replace it. I had a similar "interference" problem in a Pioneer plasma which he suggested I replace and it was the problem.
                                        Who makes this tv ? You need to get the part number from the control board.
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          A similar issue has been posted as well but also with no actual response ...
                                          08-12-2025, 04:19 AM
                                        • visionbluedemon
                                          Help. Sony kd-65x85dj vertical lines
                                          by visionbluedemon
                                          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                          tried blocking LC lines too, but same results
                                          is it lcd panel issue or tcon board issue?...
                                          07-25-2025, 04:56 AM
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
                                        • Firentiosi
                                          1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                                          by Firentiosi
                                          Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                                          The issues are as follows: the...
                                          11-27-2024, 12:33 AM
                                        • viking509
                                          vizio e65 e3 LED tv color vertical lines center tv only
                                          by viking509
                                          I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                                          03-21-2023, 12:48 AM
