Panasonic bad SC board
  • freshsta42
    • Oct 2014
    • 5
    Hi all! I have a panasonic tc-p55gt31 55" plasma tv. I am looking for an sc board since I am now getting the "seven red blinks of death" and the tv is dead. I only got about 2 years of functionality out of the tv. But anyways I cant seem to find the correct board anywhere!
    I need tnpa5335 but all i can seem to find is tnpa5335 BG or AG which seem to be both different versions. I am not sure if these will work in the tv and I dont want to risk it.
    So any idea where to find this board? thanks so much for any and all help!!
  • Ltank
    • Jun 2013
    • 776
    Re: Panasonic bad SC board
    I got a kit from ShopJimmy. It also has longer screws with lock washers. When the ground screws loosen causes arcing that damages the board.
    • dolt
      • Oct 2014
      • 6
      I also needed an SC board for my Panasonic plasma. I eventually located one on ebay after patiently looking every day for about a month. Other sites like ShopJimmy and others did not have it. They are not easy to locate and are relatively expensive.
      • tw2005
        • Oct 2011
        • 6458
        And that's why we need to keep the old core boards and start component repair because Panasonic are'nt going to produce anymore to support these Tvs.
        did you keep the old board? What model was yours?
        • dolt
          • Oct 2014
          • 6
          The TV is a TC-50PS14.
          Here's a picture of the old damaged SC board:
          If interested, I would be happy to ship it for a small fee.
          • freshsta42
            • Oct 2014
            • 5
            i also still have my board, there are no burn marks of any kind. But your right they are so hard to find online, i can only find "repair services" on ebay and they look kind of sketchy.
            • tw2005
              • Oct 2011
              • 6458
              Moduslink pTS
              • tw2005
                • Oct 2011
                • 6458
                TNPA5335BK, TNPA5335 apparent suit yours
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  Hmmph!
                  Seems that Panasonic have gone really Crappy in recent years, I would say Worse than VESTEL!...
                  I have a few dating from about 5 years to 2 years--about 5 sets in total.
                  As the sets in age get younger with the newer models, starting from the 42PZ70 which is built like a tank and working well at 16,000 hours, we then have a 42PX80--which isnt bad, fairly well made--but stuffed Mainboard, to this 2 year old TX-P42U30, which I was looking forward to fixing-
                  -Which is built like utter crap, sorta of slung together with no apparent thought whatsoever as to longevity.
                  Even looks to me that they omitted two IGBTs in the SUS side as cost-saving, There's places for three on each side of the 'SUS' switching wired in parallel, but only two were fitted. These two have got hot and marked the board--They are also Short. These two, plus the two in the ERC switching are faulty. (I suspect the ERC IGBT's failed, then took out the SUS devices....)
                  The Diodes all around there are OK.
                  There's no heatsinking on anything except the PSU parts, the IGBT's on the SN (SC/Y-SUS) are surface-mount TO220 devices, 30F131, a 360V 30A/200A pulse IGBT, that very obviously get hot as the board is scorched, the IGBTs are short, 6 of the buggers, probably driver device issues now too!
                  No Heatsinking, No 'Toad' Nothing, just the scorched board for a heatsink, no-wonder they pop off at 2 years old!
                  Looks like about 4 years ago, Panasonic lost either all interest in quality or in Plasma sets (Maybe both....), and churned out this utter pap which lasts literally 2 years--Cheapened to the point of failure. The set new was only £550 or so, yes--a cheap price for a full HD 42" Plasma, but even Vestel can outlast this tosh!
                  Ebay is full of these models with this same SN board, all with same fault. Dead/7/10 blink. Its TNPA5349 ab 'SN' Board, common to a few FHD models
                  Think I might write a stinking letter to Matsushita/Panasonic UK--just for a larf saying that this just ISNT right, and like Samsung before them, leaving themselves open to legal action, by supplying such utter crap!
                  TELEFIX
                  • freshsta42
                    • Oct 2014
                    • 5
                    Moduslink pTS
                    thanks but i already checked there and unfortunately it says they are out of stock on the tnpa5335
                    • Ltank
                      • Jun 2013
                      • 776
                      If you remove the burnt IC, look to see if the traces are burnt. Check the surrounding area for damage and replace that IC. If you can't find a good replacement then you have no choice but to try to repair it. I bought a bunch of assorted heat sink and a glue for heatsinks for these types of problems
                      • batocko
                        • Oct 2014
                        • 8
                        • serbia
                        what about st60 build quality
                        • tw2005
                          • Oct 2011
                          • 6458
                          2 options, refurbished, repair and return. You have to select the dropdown box. I don't think Ive seen a refurbished board for sale yet. $10 cheaper for yours repaired, unless you don't have your board.
                          have another look
                          • tw2005
                            • Oct 2011
                            • 6458
                            Originally posted by Alastair E
                            Hmmph!
                            TBH, If I had a 2011 model to fix, it'd be one I'd sell for profit. 2010 model ok but still they fail, I'd probably go for the PZ80/800 for logevity and one of the cheapest repairs for the 2/10 blink PSu. see them very cheap when for sale but high power usage, well built and fans to boot.
                            looking at the sc boards, I could be wrong but it looks like they started heading back to proper heatsinks near the end . Vacancies on boards, usually because of the different size screens they use more in parallel. The board and lands are the heatsinks but the higher end they did add surface mounted heatsinks and added extra sinks soldered to the PCB lands .
                            Trendy to have a thin TV I guess>
                            One thing i notice with mine (2010) the difference between my FHD and the cheaper FHD was they used a smaller cut down Sc, and no heatsinks on the SD/SU. My buffers barely get warm so probably not needed but I would agree the cheaper models are cut down in components
                            • dcapper
                              • Dec 2013
                              • 496
                              As tw2005 suggests, use Moduslink PTS. I've used them twice to repair SC boards for a 50" and 54" Panny. Just got one back today and it works great.
                              • cliff_hootarski
                                • Jul 2006
                                • 411
                                I have used Moduslink for repair of 3 mainboards and I recommend them.
                                • freshsta42
                                  • Oct 2014
                                  • 5
                                  have another look
                                  awesome! thank you!
                                  • jamie_ydr
                                    • Oct 2013
                                    • 8
                                    • united states
                                    50 bucks good board
                                    • jamie_ydr
                                      • Oct 2013
                                      • 8
                                      • united states
                                      I have one good shape. Email me at jamie_ydr@yahoo.com. 50$ plus shipping.
                                      • lookimback
                                        • Aug 2013
                                        • 1489
                                        That's probably repairable. Even if the traces are burned, there's trace repair kits.
                                        ------------signature starts here------------
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • canadaboy25
                                          Panasonic TC-P54VT25 No image. A or D board?
                                          by canadaboy25
                                          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                          01-17-2021, 01:06 AM
                                        • dajoker
                                          Panasonic th-p50s10d - blinky red, SC board go boom
                                          by dajoker
                                          My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
                                          I chased my way through the PSU, and a board, with no results.
                                          Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
                                          I only have the right half of the picture.
                                          Left half is completely blank.
                                          now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
                                          all the other voltage rails...
                                          09-24-2024, 04:39 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
