Panasonic bad SC board
+ More Options
Posts
  • Instrance
    • Nov 2015
    • Usa
    Re: Panasonic bad SC board
    Anyone have a tnpa5335bk for sale?
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
      After all of...
      07-13-2024, 08:14 PM
    • canadaboy25
      Panasonic TC-P54VT25 No image. A or D board?
      by canadaboy25
      I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
      I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
      01-17-2021, 01:06 AM
    • dajoker
      Panasonic th-p50s10d - blinky red, SC board go boom
      by dajoker
      My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
      I chased my way through the PSU, and a board, with no results.
      Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
      I only have the right half of the picture.
      Left half is completely blank.
      now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
      all the other voltage rails...
      09-24-2024, 04:39 AM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
