So I got a Dynex 46 in lcd that would turn on and work for 5 min then screen would shut off. I could tell there was a bulb out as a area in the screen wasn't lit. So I bought a new bulb of same size and thickness. On one side it solders in and the other it just pushes in. But the side that pushes is is different. The metal part that comes out the bulb winds around the bulb and my new one doesn't do that. After I installed the new bulb it lights up just like the others but then it developed the 2 sec to black issue which it did not have before replacing the bulb. Any ideas.
Dynex lcd 2 sec to black issue
Tags: None
Re: Dynex lcd 2 sec to black issue
Do y'all think its the bulb causing the 2 seconds to black since it doesn't have the coiled end -
Does it matter which way the bulb goes in one side vs the other? The model of the tv is dx-46l150a11Comment
The end of the bulb that slides down in the socket the metal that comes out of the bulb coils around the end of the bulbComment
I ended up wrapping it around the bulb and putting the bulb in the socket the bulb lights up fine but then has the 2 sec to black issueComment
I wonder if your panel uses CCFL or EEFL lamp. Do you have the panel model number?
https://cdn.badcaps-static.com/pdfs/...78a19a9c87.pdfNever stop learning
OK, it uses CCFL:
3.7 Backlight Specification
The backlight unit contains 12 CCFLs (Cold Cathode Fluorescent Lamp)
I am not sure, it does not make sense with the old lamp it will work for 5 Minutes, but with the new lamp you get 2-second to black, got to be something it does not like with the new lamp.
Did you try putting the old lamp back in?Never stop learning
I've got the same set, with a VERY similar problem. Where did you get the lamp from and what is the model, or specifications of the lamp if I was looking for one?. Also, how difficult is it to replace the lamp?Last edited by Big Jugs; 10-08-2014, 07:31 PM.Comment
So I bought a backlight inverter board cause it was cheap and it didn't fix it. I'm guessing its gonna be the bulb causing the issue so imma call up ccfl warehouse and see if they know what kind of bulb I need to get.Comment
It's not to hard to replace the lamp you just have to take the screen out of the panel to access the bulbs underneath. But be very careful as u will have to lift up the lcd screen as to not crack it or let it flop so it doesn't crack.Comment
So I have dug this one out of the closet again and starting to work on it again. I figured I would go back to basics and check all my voltages. So every voltage checks out on my power board except the 32v pin. That goes to the main board. It reads .4v and when the set turns on creeps up to .7v before the set turns backlights off. I'm wondering if it's sensing it's not getting this voltage and shutting the back lamp down. I trie tracing it on the power board but don't seem to get anywhere. Here is te part number of te power board. 6ks01320a0Comment
Also what does the det pin on te inverter board do. Cause when the tv is in standby it reads 0v then when the tv turns on and back light is on it goes up to like 70v then turns off.Comment
I have also tried wiring up another ccfl bulb and it does the same 2 sec to black. I have already swapped inverter boards so I don't think the problem is there. I also reflowed the solder joints at the bulbs on the side that solders to the copper line. All of the bulbs light up bright but then shut off after 2 secComment
by wizard13Hello everyone,
I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
I have checked the forum and the available documentation but could not find a solution specific to my issue.- Brand & Model: Dynabook Satellite Pro C50D-B-100
- Part Number (P/N): PYU13E-00C00PFR
- Serial Number (S/N): 22028896H
- System Configuration (SC): A1PYU13E1127
- Motherboard Model: IP3_ACN16_MB_V21_20211222A
- Power Input: DC 19V –
Channel: BIOS Requests ONLY!
by Ancient1Hi
Asking for a friend.
I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
but here its the opposite !
TV has new T-con = same issue
A missing panel voltage would have global effect
So , what should one do ? how can I find where the fault is ?
Thanks !... -
by ChIck3nSo I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...7 Photos
by StephenThis is not a flexgate issue.
The lcd turns on and functions fully and fine. When installing or even attempting to install an OS the screen goes black and doesn't turn on. We swapped the LCD with a testing LCD (that works) and it too is also black. After the computer cools down it turns back on and show the screen again and then it goes black when it gets hot. Sounds like a CPU issue to me (since these do not have their own dedicated GPU) but I may be wrong. Has anyone experienced this with this model? Battery is good btw. also I disconnected the battery and it still does the... -
by sgcampionHello,
Asus rog strix scar 17 G733QR
My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....10-24-2023, 09:39 AM - Loading...
