Dynex lcd 2 sec to black issue
  • Locutor13
    replied
    Re: Dynex lcd 2 sec to black issue
    I was able to remove the protection of the backlight by shorting the pin 14 "Timer" of the chip U201 to ground as shown in the attached picture. Also you will see next to the chip a series of jumpers J213,J219,J209,J208,J212 & J211 each one for smalls caps or resistors and each has two small semi circles.
    If you know the right combination you can match the settings of the ccfl according to the specifications of the protection by shorting some of those semi circles.
    Be aware that removing the protection should be done only for testing purposes as if posses a serious fire hazard.
  • Locutor13
    replied
    Hi, I have the same Dinex DX-46l150A11 with the same problem of getting the 2 sec the black issue after replacing the same ccfl (not original) of T6. Has anyone been able to find a solution?? Please Help.
  • audiofreak19
    replied
    I called ccfl warehouse and they don't sell any other kind of bulb other then the regular probe ends. So basically I think I might be screwed on this one.
  • audiofreak19
    replied
    So I looked at the panel schematics under the inverter section and all the conditions the inverter needs to see to be functional are all present on the inverter when it's off. The only thing I can think of is somethig with those bulbs. But I just don't understand it and I don't know where to get any.
  • audiofreak19
    replied
    So I tried forcing the backlights on while the main was unplugged. I jumped 5v to ps on an 5v to bon and the back light lit up for 2 sec and then shut off. So I have no idea what to check next. Anybody got any input. Getting frustrated with this one.
  • audiofreak19
    replied
    No I haven't. I wasn't sure if I could do that or not cause the backlight gets 24v but does have a bl on. What would psu be. The power on circuit.
  • newtothis
    replied
    Have you D/c'd the main then forced the PSU and BL on?
  • audiofreak19
    replied
    I have also tried wiring up another ccfl bulb and it does the same 2 sec to black. I have already swapped inverter boards so I don't think the problem is there. I also reflowed the solder joints at the bulbs on the side that solders to the copper line. All of the bulbs light up bright but then shut off after 2 sec
  • audiofreak19
    replied
    Also what does the det pin on te inverter board do. Cause when the tv is in standby it reads 0v then when the tv turns on and back light is on it goes up to like 70v then turns off.
  • audiofreak19
    replied
    So I have dug this one out of the closet again and starting to work on it again. I figured I would go back to basics and check all my voltages. So every voltage checks out on my power board except the 32v pin. That goes to the main board. It reads .4v and when the set turns on creeps up to .7v before the set turns backlights off. I'm wondering if it's sensing it's not getting this voltage and shutting the back lamp down. I trie tracing it on the power board but don't seem to get anywhere. Here is te part number of te power board. 6ks01320a0
  • audiofreak19
    replied
    It's not to hard to replace the lamp you just have to take the screen out of the panel to access the bulbs underneath. But be very careful as u will have to lift up the lcd screen as to not crack it or let it flop so it doesn't crack.
  • audiofreak19
    replied
    So I bought a backlight inverter board cause it was cheap and it didn't fix it. I'm guessing its gonna be the bulb causing the issue so imma call up ccfl warehouse and see if they know what kind of bulb I need to get.
  • Big Jugs
    replied
    I've got the same set, with a VERY similar problem. Where did you get the lamp from and what is the model, or specifications of the lamp if I was looking for one?. Also, how difficult is it to replace the lamp?
  • audiofreak19
    replied
    I would but I accidentally stepped on it and broke it lol.
    replied
    I am not sure, it does not make sense with the old lamp it will work for 5 Minutes, but with the new lamp you get 2-second to black, got to be something it does not like with the new lamp.
    Did you try putting the old lamp back in?
  • audiofreak19
    replied
    What do you think I should check next on it.
    replied
    OK, it uses CCFL:
    3.7 Backlight Specification
    The backlight unit contains 12 CCFLs (Cold Cathode Fluorescent Lamp)
  • audiofreak19
    replied
    The panel number should be t460hw03 v.f
    replied
    I wonder if your panel uses CCFL or EEFL lamp. Do you have the panel model number?
    https://cdn.badcaps-static.com/pdfs/...78a19a9c87.pdf
  • audiofreak19
    replied
    I ended up wrapping it around the bulb and putting the bulb in the socket the bulb lights up fine but then has the 2 sec to black issue
  • wizard13
    Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
    by wizard13
    I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
    I have checked the forum and the available documentation but could not find a solution specific to my issue.
    • Brand & Model: Dynabook Satellite Pro C50D-B-100
    • Part Number (P/N): PYU13E-00C00PFR
    • Serial Number (S/N): 22028896H
    • System Configuration (SC): A1PYU13E1127
    • Motherboard Model: IP3_ACN16_MB_V21_20211222A
    • Power Input: DC 19V –
    02-28-2025, 02:43 AM
  • Ancient1
    Strange LG TV issue : Image vertical lines in black screen
    by Ancient1
    Hi
    Asking for a friend.
    I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
    but here its the opposite !
    TV has new T-con = same issue
    A missing panel voltage would have global effect
    So , what should one do ? how can I find where the fault is ?
    Thanks !...
    02-05-2025, 03:37 PM
  • ChIck3n
    Dell u2311h 20000 seconds to black issue
    by ChIck3n
    So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
    09-09-2024, 11:44 AM
  • sgcampion
    Asus rog strix scar 17 G733QR display Issue(flicker, black/white))
    by sgcampion
    My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
    In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....
    10-24-2023, 09:39 AM
  • Stephen
    MacBook Pro 13" 2017 A1708 Black screen issue (not flexgate)
    by Stephen
    This is not a flexgate issue.
    The lcd turns on and functions fully and fine. When installing or even attempting to install an OS the screen goes black and doesn't turn on. We swapped the LCD with a testing LCD (that works) and it too is also black. After the computer cools down it turns back on and show the screen again and then it goes black when it gets hot. Sounds like a CPU issue to me (since these do not have their own dedicated GPU) but I may be wrong. Has anyone experienced this with this model? Battery is good btw. also I disconnected the battery and it still does the...
    06-10-2021, 09:09 AM
