Dell u2311h 20000 seconds to black issue
  • ChIck3n
    • Jun 2023
    • 9
    So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so there has to be something else. Since the monitor is still functional for now, I figured I'd ask on here to see if anyone has any idea what to try next before ripping into it again. This slow failure mode is kind of annoying, as I can't really test new components well without letting it run for days.
    I'm thinking I'll try swapping the caps on the logic board, but would they be able to cause this kind of failure at all? Or would they be showing issues other than just backlight failure? Should I swap the big one on the power board?
    Also thinking it may be the CCFL backlight itself, can I just pull CCFLs from a similar sized monitor or are they model specific? Not really sure if buying new ones is worth it for such an old monitor that I'm using for a 3rd display at this point.
    Anything else to consider? I attached the bad photos I took before, but they were mostly a reference for myself to be sure all the caps were replaced correctly. I've done a few cap swaps in monitors before, and they had fixed the problems so I was hoping it would be the same here.
  • harp
    • Jun 2022
    • 643
    • Planet Earth
    I have simmilar problem, and trubleshoot with ice cube
    https://m.youtube.com/watch?v=aPAeZWeJ-nw
    The problem was small electrolitic cap on logic board.
    You can simply recap all cap on logic board and see if help, if you dont want to pinpoint exact component.
    Also, check in dark quiet room if ccfl is produceing any hissing or visable sparc on their connector...
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8342
      My first go to would be the transformer. Compare the resistance on the two secondaries. If the difference is more than 3 %, it’s done for.
      • Rick_1234
        by Rick_1234
        Good evening, gentlemen.
        Things I tried
        06-22-2024, 04:44 PM
      • sew333
        Pc shutdown, monitor flickered with no signal after 10 seconds
        by sew333
        My pc:
        10850K stock 4800mhz stock Kraken X73 good temps
        2x16 GB DDR4 GSKILL 3000mhz XMP
        Seasonic Tx-850 Ultra Titanium
        Gigabyte Rtx 3090 Gaming OC
        Aorus Z490 Pro Gaming
        1 TB SSD
        4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
        Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
        Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
        Power...
        02-22-2022, 10:27 AM
      • zklgfs
        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
        by zklgfs
        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
        08-11-2025, 02:14 PM
      • riko 656
        Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
        by riko 656
        I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
        Laptop Model:
        • Model: Lenovo Legion Slim 5 16APH8
        • GPU: NVIDIA GeForce RTX 4070
        • Main BIOS chip size: 32MB
        • VBIOS chip size: 16MB
        Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
        What I Have Tried So Far:
        1. I
        Yesterday, 05:14 AM
      • keepread
        Dell monitor PSU vs Dell laptop PSU
        by keepread
        Hi there!
        Someone gave me their old monitor, it's Dell S2715ht.
        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
        10-30-2025, 04:45 PM
