MacBook Pro 13" 2017 A1708 Black screen issue (not flexgate)
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 676
    This is not a flexgate issue.
    The lcd turns on and functions fully and fine. When installing or even attempting to install an OS the screen goes black and doesn't turn on. We swapped the LCD with a testing LCD (that works) and it too is also black. After the computer cools down it turns back on and show the screen again and then it goes black when it gets hot. Sounds like a CPU issue to me (since these do not have their own dedicated GPU) but I may be wrong. Has anyone experienced this with this model? Battery is good btw. also I disconnected the battery and it still does the same thing. Also the computer is still on and hot when the screen goes black. Voltage is still going. So I am assuming it is something else. I am curious what it might be? Logic board repair would be easy if we knew this issue but this is a first for us in this model so I am thinking CPU (intel chip) is bad but that could be something along the line that the CPU (intel chip) is fine but something that is connected to it is causing issues.
    Any suggestions?
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 676
    Re: MacBook Pro 13" 2017 A1708 Black screen issue (not flexgate)
    Side note: Plugged up the computer to an external when it was cold, external monitor displays when in OS install (catalina) when it gets close to installing and (2 mins left before it goes into the Apple Logo it goes black like the computer. The TV now shows no signal and the LCD is black as well. I am suspecting the CPU is the culprit and is getting to hot and turns itself off. The fan is on but it is black. When the computer is cold it turns on showing the LCD and monitor. Any suggestions. Most likely leaning towards a failing CPU but odd it works when it is cold.
    sigpic
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 676
      Bumping thread. Any comments?
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 676
        Well guess no ideas huh?
        sigpic
        • peste
          • 13891
          • ROMANIA
          the video chip is probably in trouble.
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 676
            You mean the CPU? Because these are single based graphics integrated with the CPU.
            sigpic
            • mon2
              • 14801
              Does the vice-versa hold true ?
              That is, if you freeze spray / cool the CPU, does the unit remain stable longer ?
              Have you reviewed the heatsink compound? Apply a fresh batch and be sure that it is securely keeping the CPU cool enough to operate normally.
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 676
                Hey mon2,
                I will do that first thing tomorrow when I get back to the shop. I should maybe apply some new thermal and see if that is the case. Chances are it could be overheating and it turns itself off to prevent further problems. I wont know till I get in tomorrow. I will test it out.
                sigpic
                • Stephen
                  Meow Meow MEOW!
                  • Apr 2020
                  • 676
                  Hey mon2
                  So installed new thermal paste and cleaned up the CPU. Also installed another SSD with a known operating system that is working and it booted up to the home screen. within 10 seconds after booting up. The computer froze and the screen went black after. Touched the CPU and it is scorching hot. This is after new thermal paste is applied and even the fan was on and it still couldn't cool itself off. It seems the CPU is working but it is getting overheated. Any suggestions?
                  Also no signs of water damage under the microscope. Seems like a healthy board.
                  sigpic
                    • 22236
                    Hey mon2
                    If the board has been reworked near the heatsink without removing it,it could be damaged. Take the heat sink off, heat the pipe above cpu end to 100 degrees or so, if the pipe is still cool at the other end the heatsink is broke.
                    • Stephen
                      Meow Meow MEOW!
                      • Apr 2020
                      • 676
                      Awe this is a different angle. I will try this now! Thank you for this idea!
                      sigpic
                      • Stephen
                        Meow Meow MEOW!
                        • Apr 2020
                        • 676
                        Heated the pipe. It gets hot on the other end so the Heatsink is good.
                        sigpic
                        • mon2
                          • 14801
                          Can you confirm that the heatsink is on securely and on top of the CPU surface area? Very important for the heatsink to be properly fastened to allow this component to remove the heat off the CPU.
                          Also, the heatsink compound is known to be good ? I know that when we do iMAC repairs, for at least the heatsink pads, the stuff @ Digikey is much better material and keeps the video cards cooler than others we have attempted in the past.
                          We have met them at past trade fairs in Tapei and HK. Our engineers and from personal experience found them to be the best to date to dissipate the heat. However they are more expensive.
                          https://tglobalcorp.com/
                          You can buy through Digikey. Apparently they also sell the paste as well.
                          Can you feel the heatsink getting hotter as the unit runs ? It should.
                          • Stephen
                            Meow Meow MEOW!
                            • Apr 2020
                            • 676
                            mon2,
                            yes the heatsink is good and the heat dissapates to the full heatsink. Even with new thermal paste it does fine. The CPU just gets VERY hot still none the less and that heat goes to the end of the Heatsink as well. So CPU is overheating and I am assuming it could be somewhere around that area that needs to be replaced. Maybe a thermal sensor?
                            sigpic
                            • pantsos
                              • Feb 2021
                              • 13
                              It seems like a have the exact same issue. Can you try to close the lid and open again, image comes on or it stays off?
                              I’m my case when image goes off I close the lid and re open and it works for a few seconds and then again goes off.
                              • Stephen
                                Meow Meow MEOW!
                                • Apr 2020
                                • 676
                                What you probably have is a flexgate issue. My image disappears even when plugged up externally.
                                sigpic
                                • sofles
                                  Macbook a1707 2017 model 820-00928 GPU issue
                                  by sofles
                                  Hello there
                                  I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                  I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                  11-21-2024, 05:25 AM
                                • rounin
                                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                  by rounin
                                  I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                  🛠 Original Issue
                                  The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                  04-19-2025, 01:18 AM
                                • Riananyaina
                                  MacBook A1708 820-00840-A backlight issue
                                  by Riananyaina
                                  Hello Everyone ,
                                  today I'm coming to you regarding my issue which is no Backlight .
                                  I have image on my screen but no light .
                                  The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
                                  First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
                                  Please find below few informations which can help for the analysis...
                                  04-24-2023, 05:03 AM
                                • Instafixx
                                  Macbook A1708 820-0040 Camera Issue
                                  by Instafixx
                                  Namaste.
                                  I have this Macbook A1708 830-00840 with a No Camera Issue.
                                  System Report says that no video capturing device is attached.
                                  Installed a known good display assembly with working front camera but still the same.
                                  The motherboard is clean. No Liquid Damage.
                                  Can anyone help?
                                  05-08-2023, 06:26 AM
                                • slimmy182
                                  MacBook Pro 15" 2016 820-00281 no backlight. Another flexgate issue?
                                  by slimmy182
                                  Hello, I bought this machine from a friend. It's a 15 inch MacBook Pro 2016 model, logic board 820-00281. He said that the screen would go off if open more than a certaing angle but it's perfect working whit an external display.
                                  The backlight screen remains stay off even if I open just a little the lid, so I never see backlight work, but I can confirm that LCD show images as using a torch I can see it on the screen. It seems also that camera is not rocognized as the keyboard backlight stay off and touchbar have full brightness.
                                  Is this a classic flexgate issue? I...
                                  10-19-2022, 12:44 AM
