i need guidance on how to find a electronics job
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Ok I did some tech school and got jstd001 and ipca610 soldering circuit boards. Electronic assembly and I have a yr under my belt of doing TV repair. I can do LCDs and led but have trouble with plasmas and have worked on a few dlps. I would like to get a job. But I don't know what type of fields I could get into with this soldering certifications. Possibly would like to get a job going out in the fields to do house calls for TV repair. Can anybody guide me on what are my options or where to look. Thanks
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Re: i need guidance on how to find a electronics job
    Any help please
    • Ltank
      • Jun 2013
      • 776
      I retired from Offshore Industrial Electronic Technician. I had two year trade school but got a lot of certifications on my own.
      Look online at ETA .ORG or ISCET they have testing and certifications that are available through proctor ed exams at College's. The give you a list of books to read and study. They are not easy but you would be a step above others that apply for the same job.
      I am certified in Six different fields of electronics.
      • mattstolte
        • Dec 2013
        • 612
        • usa
        What I'm asking is though is what type of jobs can I even get? Like I don't know what all fields could use me
        • Stephan829
          • Apr 2021
          • United Kingdom
          Finding a compatible job which match your skills is not easy. I have and I think it's a good online learning platform for students. Hope to see more informational stuff
          • alfatv
            • Sep 2020
            • 353
            Doing TV repairs is not a good job and even running your business is very tough, but you can try.
            It's much better to service some expensive professional equipment like medical for example.
            Also hi-tech companies normally have R&D and test labs, there is some good work for technicians over there.
            • R_J
              • 9588
              TV/consumer electronics repair is dead as far as a business, Better to be a plumber or electrician or almost anything else these days.
              • angelos
                • Dec 2012
                • 573
                • South Africa
                Plumber I guess that occupation will never become obsolete as long as bart is there!!!
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • Hypersapien
                  Artist seeking to tinker with electronics safely
                  by Hypersapien
                  Howdy folks! I'm an artist in the video game industry, and my job entails making a lot of mechanical and sci fi assets. I thought it might be a good practice to start disassembling some electronics to be more familiar with how real electronics are manufactured and assembled, which is how i found my way to these forums.
                  When I started researching what tools I might need, I quickly encountered the warning "Some devices can maintain a potentially lethal charge in their capacitors, even up to years after last being powered on", which was enough of a scary thought for me to...
                  10-22-2023, 01:31 PM
                • danielgerman681
                  ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                  by danielgerman681
                  Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                  08-27-2025, 01:17 PM
                • corrize
                  Where to find a very small fpc connector 0.3mm between 2 pins ?
                  by corrize
                  Hello, I search this connector (oxydated).
                  It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                  I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                  I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                  Do you know how to find this connector please ? What is the exact name for find it ?
                  08-06-2024, 05:25 PM
                  Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                  by sam_sam_sam
                  This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                  Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                  07-07-2024, 02:34 PM
