i need guidance on how to find a electronics job
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Ok I did some tech school and got jstd001 and ipca610 soldering circuit boards. Electronic assembly and I have a yr under my belt of doing TV repair. I can do LCDs and led but have trouble with plasmas and have worked on a few dlps. I would like to get a job. But I don't know what type of fields I could get into with this soldering certifications. Possibly would like to get a job going out in the fields to do house calls for TV repair. Can anybody guide me on what are my options or where to look. Thanks
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Re: i need guidance on how to find a electronics job
    Any help please
    • Ltank
      • Jun 2013
      • 776
      I retired from Offshore Industrial Electronic Technician. I had two year trade school but got a lot of certifications on my own.
      Look online at ETA .ORG or ISCET they have testing and certifications that are available through proctor ed exams at College's. The give you a list of books to read and study. They are not easy but you would be a step above others that apply for the same job.
      I am certified in Six different fields of electronics.
      • mattstolte
        • Dec 2013
        • 612
        • usa
        What I'm asking is though is what type of jobs can I even get? Like I don't know what all fields could use me
        • Stephan829
          • Apr 2021
          • United Kingdom
          Finding a compatible job which match your skills is not easy. I have and I think it's a good online learning platform for students. Hope to see more informational stuff
          • alfatv
            • Sep 2020
            • 353
            Doing TV repairs is not a good job and even running your business is very tough, but you can try.
            It's much better to service some expensive professional equipment like medical for example.
            Also hi-tech companies normally have R&D and test labs, there is some good work for technicians over there.
            • R_J
              • 9555
              TV/consumer electronics repair is dead as far as a business, Better to be a plumber or electrician or almost anything else these days.
              • angelos
                • Dec 2012
                • 571
                • South Africa
                Plumber I guess that occupation will never become obsolete as long as bart is there!!!
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • Hypersapien
                  Artist seeking to tinker with electronics safely
                  by Hypersapien
                  Howdy folks! I'm an artist in the video game industry, and my job entails making a lot of mechanical and sci fi assets. I thought it might be a good practice to start disassembling some electronics to be more familiar with how real electronics are manufactured and assembled, which is how i found my way to these forums.
                  When I started researching what tools I might need, I quickly encountered the warning "Some devices can maintain a potentially lethal charge in their capacitors, even up to years after last being powered on", which was enough of a scary thought for me to...
                  10-22-2023, 01:31 PM
                • corrize
                  Where to find a very small fpc connector 0.3mm between 2 pins ?
                  by corrize
                  Hello, I search this connector (oxydated).
                  It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                  I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                  I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                  Do you know how to find this connector please ? What is the exact name for find it ?
                  08-06-2024, 05:25 PM
                  Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                  by sam_sam_sam
                  This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                  Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                  07-07-2024, 02:34 PM
                  Multifix 425-01 and 450-01 Rework Flux Datasheet
                  REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                  - No Clean Formulations
                  - Low residue
                  - Range of activity to deal with different component solderability
                  - Halide free
                  - Suitable for dispensing
                  - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                  Both products are supplied in syringes or cartridges for application by dispensing....
                  10-07-2024, 06:02 AM
