Philips 55PUS6704 no picture, backlight ok
  • lotas
    • Jan 2016
    • 4850
    • Russia
    On these LG T-CONs, in addition to 12v, you also need to supply 3.3v to a specific point on the T-CON or move a specific smd resistor to put it into test mode (color selection), but I don’t know what and how about this T-CON
    • Diah
      • Feb 2013
      • 6558
      No need 3.3V, it had SPI U1 Pin 8 should have 3.3V you can measure it when you supply 12V to F1 as T-CON Panel standalone test... much like Panel VCC at thin film have brocken some where need deep investigated before play with SoC
      • Patrick501
        • Oct 2024
        • 53
        I couldn't find any damage on or around the connection of the panel
        I felt like this TV had a million of screws to get to the panel.
        • Diah
          • Feb 2013
          • 6558
          only the Bezel need to remove... however do the test again with 12V and measure U1 PIN8 if there 3.3V
          • lotas
            • Jan 2016
            • 4850
            • Russia
            How is it not necessary? You need to supply these 3.3v, which are converted into T-CON via a jumper, to a specific point and thus the controller goes into test mode!
            • Diah
              • Feb 2013
              • 6558
              no need to feed 3.3V i asked him to measure just in case if T_CON PWM didn't generate it.. we have in this forum same T-CON and it start to do color pattern just with 12V.
              this why i asked him to inspect LCD Glass before going to GPU
              • Patrick501
                • Oct 2024
                • 53
                I'm probably gonna get a second TV, exact same model. I will switch parts then and see which one is at fault. So I can repair both of them.
                Thanks for your help and knowledge! I really appreciate it.
                • lotas
                  • Jan 2016
                  • 4850
                  • Russia
                  #28
                  There have been cases of poor soldering of these connectors on the buffer strips. Inspect carefully with a magnifying glass to see if there are any bad soldering (cracks) between the connector pins and the board.
                  • Diah
                    • Feb 2013
                    • 6558
                    its 0.1% will be soldering crack at ribbon socket at panel or T-COn, but it could be the clip expanded and didn't make enough pressure to hold ribbon in place,,, but this also unlike unless the ribbon contact pins damaged because of the age and heat when user disconnect them many time.
                    still i think need to inspect the corners of the LCD with out Bezel if there damage at glass edge.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4537
                      • Italy - Milan
                      #30
                      Hi, the white half screen means you have probably correct gate drivers signal but you have no data, this means probably you don't have source vdd, you have to check the correct points on the strip boards, check wheter on the bigger caps you have near 17v, if you do not have it check the correct point on tcon for same voltage, so check every.bigger cap and see if one has missing volts, the correct one is connected to cathode of a power diode.. inspect strip boards for corrosion..
                      • Patrick501
                        • Oct 2024
                        • 53
                        the white part is where the screen is disconnected.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4537
                          • Italy - Milan
                          #32
                          Yes i know don't worry
                          • triplefour
                            by triplefour
                            09-13-2023, 10:43 PM
                          • TR103
                            by TR103
                            - it keeps rebooting
                            01-22-2025, 04:12 PM
                          • markolino
                            Philips 58PUS7505/12 Backlight OK / no picture.. Help
                            by markolino
                            overnight my philips is 2 years old but unfortunately it is no longer under warranty.. started joking..
                            the picture became black.. but the next day when I turned it on, I still saw a little something... But now it's just black..
                            the backlight works normally.. the sound too.. the motherboard also shows that it is ok..
                            I suspect a T-Con panel. Do you think the panel is shorted?
                            below I am sending you a video about my TV and how it behaves.
                            I also tried disconnecting the ribbon cables. first the left one, then the right one.. but I can't find out if the panel has...
                            09-20-2023, 05:07 PM
                          • Mgiffune
                            by Mgiffune
                            06-09-2024, 10:28 AM
                          • chestercc
                            Philips TV Backlight Repair
                            by chestercc
                            So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
                            My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
                            The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
                            11-18-2022, 01:15 PM
