Technika LCD 32-270 - stuck in standby
+ More Options
Posts
  • tn245
    • Oct 2013
    • 530
    Re: Technika LCD 32-270 - stuck in standby
    if you freeze the spi chip does the set start if it does take a copy of the file i have saw this method mentioned a few times even norcal on youtube has a video on it.
    https://www.youtube.com/watch?v=Qy8fh-g5DOM
    Good call! Do you know what I had actually tried freezing it yesterday with no luck. But after you suggested it I thought I'll give it another go just now and it came on. I'll see if I can get a dump from the chip. Thanks!
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      ive found its also the ammount you freeze the chip too i usually use air duster upside down to freeze stuff but i save a proper can of electronics freeze spray for jobs like this as seems to work better, i just need to learn how to use my cheap ebay eeprom reader writer better and not to lift the pads on the eeproms pcb.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Give that a try, should work If not you can get recoded replacements from Ohm supplies I think.
        • tn245
          • Oct 2013
          • 530
          I'm using air duster too. I gave it a bit of a longer blast this time so must have frozen it better. Will try to lift the software later today,
          • tn245
            • Oct 2013
            • 530
            Just to report back. I successfully extracted the data from the SPI chip and got the TV working with a new one. Thanks again for the help!
            • lepak06
              TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
              by lepak06
              Hello
              I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
              The TV is faulty with stuck in Standby RED LED. Can't power the TV.
              Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
              All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
              But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
              01-12-2023, 01:43 AM
            • toty79
              Hisense LTDN50K220WSEU stuck in standby
              by toty79
              Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
              As per Hisense tv title LTDN50K220WSEU stuck in standby
              PSU rsag.820.5687 HLL 4855WF
              Main rsag 7.820.5842
              I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
              05-01-2022, 04:39 PM
            • lego1234567
              LG 32LB1R - stuck in standby mode
              by lego1234567
              Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
              What could be the problem ? Thanks...
              01-21-2024, 03:39 AM
            • Stunt
              Hp Laptop Stuck on Hp protected by hp sure start screen
              by Stunt
              Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
              I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
              I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
              Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
              screen that's it and stuck there. I left it until the following day and i still...
              09-02-2025, 01:51 PM
            • Rusenga
              Samsung UA39EH5003R Stuck on standby
              by Rusenga
              Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
              Connector CNM803:
              TV ON
              Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
              TV OFF
              Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
              09-18-2021, 11:51 AM
