Technika LCD 32-270 - stuck in standby
  • drw25
    • Sep 2014
    • 13
    Hi there,
    I've got a Technika LCD 32-270 (aka. M32/57G-GB-FTCU-UK), which is currently stuck in standby. When the power supply is on, it simply lights the red standby LED, and shows no sign of life when I press buttons on the side panel or remote control.
    Directly before this happened, the TV picture was replaced by a bright green distorted mess and the sound by loud white noise - this lasted a few seconds before it turned itself off and went to standby. The same thing also happened a few months ago, after which I left it turned off for a number of weeks, and it miraculously started to work again until now!
    I've opened it up and had a look at the capacitors - no obvious bulging, but there is some gunk on the positive leg of C7 on the PSU board (see pics). +5VSB measures about 4.9V constantly on my multimeter and +5V about 4.7V, +12V is very low (varying between approx. 0-4V) and +24V is dead. Should I expect all these voltages to be high, even in standby, or are they only turned on if the logic board asks for them? I guess I'm mostly trying to work out if it's the PSU or logic board at fault here.
    Any recommendations for my next move?
    Thanks in advance!
    Dan
  • handsomedude
    • Sep 2014
    • wales
    Re: Technika LCD 32-270 - stuck in standby
    c7 on picture 1 not good. change it
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Ok I have worked on one of these before they are nasty poorly built sets,the psu had the same issue you have I found the fault to be it to be a bad switching transistor on the primary side firstly desolder them and check them, do you know how to check them ?
      Also check c7 (primary) cap as it appears to be leaking ?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Agreed...C7 needs to be replaced....99% sure this will solve the problem.....1% it may also be something else.
        • drw25
          • Sep 2014
          • 13
          Thanks guys - I've ordered a replacement for C7 - will let you know how I get on!
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            It might not be c7 as if that failed there would be no voltages at all but try that first to rule that theroy out.
            • drw25
              • Sep 2014
              • 13
              Changed C7 but ReeceyBurger was right - it didn't fix things. I'm wondering if it might be a logic board problem, given the corrupted video and sound beforehand, but power supply components are cheaper than buying a new board so worth ruling them out first! I guess I should be checking ICS1, ICS4 and Q5 (in pic 2) in terms of transistors?
                Are there any labeling on the connectors of the power supply? You need to find the PS_ON pin which gets the signal from the main board to turn on the rest of the power supply. Please read my Basic LCD TV Troubleshooting guide.
                • drw25
                  • Sep 2014
                  • 13
                  Thanks for your message budm. Just tried triggering PS_ON myself with a resistor to 5VSB, then:
                  24V rail measures 23.4V
                  12V rail measures 11.8V
                  5V measures 4.8V
                  5VSB measures approx 5V
                  These look OK to me, so seems the problem is outside the PSU?
                    Yes, that means the main board is not sending the signal to turn on the power supply
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Ok on the main board there will be a set of resistors I will put a ring a round them, they should send the psu start signal.
                      • flocko
                        • Nov 2012
                        • 1121
                        As you have correct voltages from power board, I would put my money on the eeprom on the main board normally U10 on these T.MSL 306 main boards ,but were you get one that another story ? but don't try to short it that will not work Flocko
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Try the eeprom first if not I will show you what to check next.
                            There are 3-pin Voltage regulators on the main board that you need to test the Voltages on all 3 pins.
                            • flocko
                              • Nov 2012
                              • 1121
                              Hi just had on look on OHM Supplies site they list eeproms for Technikas with T.MSL 306 mains but not with your board number ( T.MSL 306 6B 10251 ) and as Andy has the biggest range of eeproms over here in the uk, I think you will have to get replacement board its a common problem with these sets Flocko
                              • Clydeuk
                                • Jan 2012
                                • 193
                                If you can be bothered trying to cope with Russian translation monitor.net.ru has a lot of EEPROM dumps, only useful if you have something to program them with though. I doubt you'll find a match but using the board number you may find something close. Obviously no guarantee if you can even find one that it will be any good options wise.
                                • drw25
                                  • Sep 2014
                                  • 13
                                  Can report that a new logic board fixed it. Unfortunately the screen got cracked moving house so it's now a write-off, but good to have found the solution to the problem! Thanks all for your help.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Thats a pain, normaly replacement lcd screens for these sets are around £130 but its not worth it as you can get a good 32" lg for around £250 that will last alot longer than this junk.
                                    Take care pal
                                    • tn245
                                      • Oct 2013
                                      • 530
                                      Hi. I have the same model with the same problem. Does anyone have the firmware bin file for the SPI? I can write the SPI myself so no point buying a programmed chip. Thanks!
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        if you freeze the spi chip does the set start if it does take a copy of the file i have saw this method mentioned a few times even norcal on youtube has a video on it.
                                        https://www.youtube.com/watch?v=Qy8fh-g5DOM
                                        • lepak06
                                          TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                          by lepak06
                                          Hello
                                          I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                          The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                          Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                          All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                          But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                          01-12-2023, 01:43 AM
                                        • toty79
                                          Hisense LTDN50K220WSEU stuck in standby
                                          by toty79
                                          Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                          As per Hisense tv title LTDN50K220WSEU stuck in standby
                                          PSU rsag.820.5687 HLL 4855WF
                                          Main rsag 7.820.5842
                                          I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                          05-01-2022, 04:39 PM
                                        • lego1234567
                                          LG 32LB1R - stuck in standby mode
                                          by lego1234567
                                          Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                          What could be the problem ? Thanks...
                                          01-21-2024, 03:39 AM
                                        • Rusenga
                                          Samsung UA39EH5003R Stuck on standby
                                          by Rusenga
                                          Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                          Connector CNM803:
                                          TV ON
                                          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                          TV OFF
                                          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                          09-18-2021, 11:51 AM
                                        • Ukdigger
                                          Samsung UE46f5000AK Stuck on Standby
                                          by Ukdigger
                                          When the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
                                          PSU number bn44-00610A L46SF_dpn
                                          1 B13v 12.4
                                          3 B13v 12.4
                                          5 Vamp 12.4
                                          7 Vamp 12.4
                                          9 GND...
                                          08-08-2024, 09:17 AM
