Had the set hanging around I gets backlight but no picture or menu. I have read that they have bad T-Cons so I looked over the board and found a burnt to a crisp QP7 I have no number to go by I have a picture from SJ the same as mine but theirs has the part that burnt out on my board. Does any one know the number of this part?
Westinghouse LTV32w6 HD Need help to ID a component
Tags: None
Re: Westinghouse LTV32w6 HD Need help to ID a component
Can you take the resistance readings of all 3 pins against the Ground trace (mounting hole copper plane)? 1= left pin, 2 = top pin, 3 = right pin.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
There is nothing left of it I was just a whitish powder. I tried to clean it and It just washed away.Comment
But there should be at least 3 solder pads, right? I can see at least two pads in the picture.Never stop learning
top pin - 3.730 K ohm
left pin- 3.98 K ohm
right pin - M ohm climbed untill it reached O.LComment
right pin started at 26.00 M ohm climbed to O.LComment
OK, at least none of the pins are connected to a dead shorted circuit that caused it to burn up like that. We need to find out next the function of this Transistor/MOSFET and how all these pins are connected to.Never stop learning
I have my magnifier out ,and I will try to follow the pads.
I will draw a picture of what I find.Comment
I put a used t-con in,and I got a picture but then faded to black. Noise coming from speakers hi pitch squeal. I thought maybe bad caps on ps. I checked all the caps all ok I used an esr meter. I put the power board back in and now nothing. No volts coming out. Yes I did recheck my solder all good. Here are a couple pics.Comment
hmm not even standby, did something maybe blow your power supply fuse?Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Fuse is good I have power at main caps,and bridge rec. No power on cold side of ps board.Comment
maybe check the thread by ben3843100, I just bumped it, for easy location, good info there, even tho ben didn't FOLLOW UP.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
https://www.badcaps.net/forum/showthread.php?t=13258 thats the thread.Last edited by nomoresonys; 02-06-2015, 09:46 AM.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
A quick background on what happens at startup on these supplies. AC power is applied, the mains filter cap charges to full voltage (1.4 x line voltage). A low current path (bleeder resistor or constant current source in the SMPS controller) charges the Vcc filter cap to (usually) about 16V. At that point the SMPS controller starts.
The SMPS controller turns on the main power FET briefly, sending a surge of current through the primary if the transformer, causing pulses of current through the secondaries and a tertiary winding which provides Vcc for the SMPS controller. This is followed by additional pulses until the secondary voltage reaches the design value - usually 5 volts.
There are a few things that can stop this start-up cycle. If the Vcc filter cap is open, Vcc decays to below 10 volts and the process stops before the tertiary winding can provide enough voltage. An excessive load on the secondary will have the same effect. That can be a reversed cap, bad diodes, short on one of the loads, etc.
I'd have to see the part numbers of U2 and U4, but it appears to me that U4 is most likely the SMPS controller, mainly because of it's proximity to the opto-isolator.
PlainBill. Nice explanation of start up, post #28 of bens thread, Thanks Plain Bill.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
I just ordered a guaranteed power supply,and I will reverse engineer it to find the bad parts. Be back when it comes in.Comment
by dicky96Hi guys
This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
The good phase... -
by mferna14Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
by nobbnobb1I picked up this used Bose Acoustimass 10 IV speaker system. Speakers seem to work fine, but the subwoofer does not make any noise. So I took apart the unit and found some obviously failed (burnt) components:
- 1x 3.14 A @ 250V main circuit fuse
- 1x bridge rectifier GBU601. there's actually two of these on the board, one is obviously burnt and the other does not seem to have any anomalies like shorts. However I figure may as well replace both.
- 2x diode. This is tricky because the only markings I see on it are: "617 402". No current rating or anything else....-
by CG2I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple...3 Photos
by jm1234Hi,
this is a Siemens induction panel, one side seems damaged, I attached both good and burnt picture to compare. I'm not sure what those rectangles a are for, but they are connected by a solder. That seems to be what got burnt, so I'm wondering it that was some kind of a protection. Do I just try to re-solder them?
Thanks,
Daniel... - Loading...
