Lg 47lm860v 3d tv- no picture
Wow...I’ve been nothing but polite and accommodating, yet I encountered rudeness that was unnecessary and really perturbed me. This behaviour is not acceptable and gives the forum a bad image. I hope this is not your normal attitude. As someone new to forums, I’m still figuring things out, and it would have been more constructive to raise concerns respectfully. Communication can be tough, but respect should always be part of the conversation. I get comfort from Karma so I'll sleep soundly tonight...will you!!!Comment
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
I have a VIZIO E70-E3.
Symptoms: Black screen, no picture, but LED backlights are working.
I probed the power board and voltages are as listed on the board.
Main board appears fine, too.
I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
There are two separate ribbon cables feeding the LCD.
If both are connected, the screen is black.
If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and... -
by noisykid5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
by iglitareHi,
Or is it always a bad/shorted... -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... - Loading...
