Lg 47lm860v 3d tv- no picture
  • Longon
    long
    • Jul 2025
    • 33
    • United Kingdom
    #41
    Originally posted by Diah
    GPU could not tested panel in stand alone... yours issue at MB. if the panel buffer boards didn't suffer from liquid damage at buffer boardsb
    Hi Diah.....Was this message meant for me? if so I'm confused!!
    Long
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4423
      • Italy - Milan
      #42
      on the tcon , near the input connector between 2 caps there is an inductance, small, check it both sides for voltage, i forgot to say it, where do you have soldered the 12v wire? in saw on fuse but there is no fuse so you had to use that inductance..
      • Diah
        • Feb 2013
        • 6416
        Long
        yes its
        again this non T-CON, this is GPU circuit of early LM series.. later they installed it at MB, this why you will not find any Fuse of 12V. cause its going with 3.3V line too to operate FRC.. answers from others ignore its just fantasy ... who knows when he have this early version and later under hist hand.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4423
          • Italy - Milan
          #44
          Tcon is full of 7 converters as usual, so it starts as usual 12v then stepped down or up depends on the converter.. plus, the tcon asic is always the last prior the panel, it does not exist FRC after Tcon, THIS is Fantasy!
          • Longon
            long
            • Jul 2025
            • 33
            • United Kingdom
            #45
            Hey D....Is this the location of where you mentioned, I'm guessing you meant inductor (inductance) and not clear what you mean "in saw on fuse but there is no fuse so you had to use that inductance." There are no fuses on the T-con or main board as far as I can make out..
            I measured both ways and all I'm getting is a nominal 9.8mv
            • Longon
              long
              • Jul 2025
              • 33
              • United Kingdom
              #46
              yes its
              Hi Diah....Whats your feelings on this issue, as...if I'm correct, there seems to be a difference in opinion which I seem to be stuck in the middle!!
              Long
              • Longon
                long
                • Jul 2025
                • 33
                • United Kingdom
                #47
                Diah can you also explain what you meant #34??
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4423
                  • Italy - Milan
                  #48
                  Sorry, the idiot who projected Android obliges me to the automatic corrector, i mean, the inductor it's maybe used instead as fuse and is toghether an inrush current limiter, i don't know, so in your screen stand alone test, where do you put the side of wire for injecting 12v to tcon? 9mv has no sense, i trust you do not see a thing so! I do not remeber my old post, but toghether with the jumping wiire to tcon you need also to do 2 jumpers on the power board to enable full on PSB and backlight, if you aren't able i tell you how, i need PSB output table schematic if there isn't
                  PS: jump 3,5v to PWR-ON and to DRV-ON
                  • Longon
                    long
                    • Jul 2025
                    • 33
                    • United Kingdom
                    #49
                    Originally posted by lotas
                    If T-CON sees any faults (low resistance or short circuit) on the output voltages for the panel, it blocks them, disconnect one cable from T-CON and the panel (from the T-CON side) and turn on the TV and see what's wrong with the image, then reconnect the cable and disconnect the second one and also check the image (the image will appear on at least half of the screen).
                    Hey Lotas...I tried your advice again only this time I left a little longer than previously and not sure if this makes any difference but this time the screen changed drastically as you can see from the attached..
                    • Diah
                      • Feb 2013
                      • 6416
                      Long
                      if the panel dint have any liquid damage on the buffer boards , then refllow the chip on MB IC9300
                      • Longon
                        long
                        • Jul 2025
                        • 33
                        • United Kingdom
                        #51
                        Davi if this helps I found the schematic for the PSU..
                        https://elektrotanya.com/lg_eay62512.../download.html
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4423
                          • Italy - Milan
                          #52
                          i don't want a schematic, only the pinout of connector..
                          what you show on the last pic is normal for lg screens, them don't show image if half connected, only bars, my opinion screen is ok but wait for the test
                          • Longon
                            long
                            • Jul 2025
                            • 33
                            • United Kingdom
                            #53
                            Davi... As requested pinout connectors. If you need anything else that I've missed then let me know.
                            Click image for larger version  Name:	20250910_220138.jpg Views:	0 Size:	325.4 KB ID:	3726463
                            With regards to....PS: jump 3,5v to PWR-ON and to DRV-ON, these already have a supply.....
                            and you say "enable full on PSB and backlight, if you aren't able i tell you how, i need PSB output table schematic if there isn't"
                            The backlight has always came on with no problems?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4423
                              • Italy - Milan
                              #54
                              I do not like your way of participate to this forum, i asked for a picture means obvioisly a clear picture, i already told you what to do on the basis of what you produce (text, photos), if you decide to do something let me know.. otherwise it becomes a very boring discussion.. bye..
                              • Longon
                                long
                                • Jul 2025
                                • 33
                                • United Kingdom
                                #55
                                Hi Diah......When you say reflow the chip, I'm guessing using flux, what temp and for how long roughly? Need to ask as never actually tried before!!
                                • Diah
                                  • Feb 2013
                                  • 6416
                                  the best way for this chip... put tape on it which it used at wall or car painting 2 layers. not only the chip but around too to avoid any SMT Parts fly our or the socket formed. in case you use hot air gun. with high temperature 350° the gun put it 2cm away from the chip and don't move it left and right... focused the air on the chip self only.... untill the paper tape you put early burned brawn black... then leave it to cool down... this method applied only for hot air gun
                                  • Longon
                                    long
                                    • Jul 2025
                                    • 33
                                    • United Kingdom
                                    #57
                                    Wow...I’ve been nothing but polite and accommodating, yet I encountered rudeness that was unnecessary and really perturbed me. This behaviour is not acceptable and gives the forum a bad image. I hope this is not your normal attitude. As someone new to forums, I’m still figuring things out, and it would have been more constructive to raise concerns respectfully. Communication can be tough, but respect should always be part of the conversation. I get comfort from Karma so I'll sleep soundly tonight...will you!!!
                                    • Longon
                                      long
                                      • Jul 2025
                                      • 33
                                      • United Kingdom
                                      #58
                                      Shall I use flux?
                                      • Diah
                                        • Feb 2013
                                        • 6416
                                        Shall I use flux?
                                        depend on the quality of yours Flux. however its hard to let it go under the chip
                                        • Longon
                                          long
                                          • Jul 2025
                                          • 33
                                          • United Kingdom
                                          #60
                                          Have flux in syringe, or should I try without first?
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • Fly_Among_Stars
                                            VIZIO E70-E3 Half picture with half TCON
                                            by Fly_Among_Stars
                                            I have a VIZIO E70-E3.
                                            Symptoms: Black screen, no picture, but LED backlights are working.
                                            I probed the power board and voltages are as listed on the board.
                                            Main board appears fine, too.
                                            I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                            There are two separate ribbon cables feeding the LCD.
                                            If both are connected, the screen is black.
                                            If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                            04-24-2023, 08:20 PM
                                          • noisykid
                                            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                            by noisykid
                                            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                            12-30-2024, 07:15 PM
                                          • iglitare
                                            by iglitare
                                            09-04-2025, 07:13 AM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
