T-con Interchangeability LG 47LG50
  • 69sixpackbee
    • Jul 2014
    • 39
    Hi, folks,
    The T-con board on my LG 47LG50 has a part # on the sticker of 35-D020223 and it is a V420H1-C07 part #silkscreened on the board itself.
    There are many different TV manufacturers that use this V420H1-C07 board.
    Are these interchangeable possibly?
    Thanx,
    Bud
  • selldoor
    Slow Learner
    • 7870
    Re: T-con Interchangeability LG 47LG50
    Probably not -I believe they have to be matched to the panel - just look around shop jimmy
    doing different searches and see what comes up
    That may not be the case for LG the part number seems to be specific but some may still be compatible
    https://www.youtube.com/watch?v=J1GmfoeQeP4
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Yep. Shopjimmy has the list of TVs with that panel. You need to match the number on the sticker too 35-D020223
      Looks like they have two listed the are compatible.
      http://www.shopjimmy.com/cmo-35-d020223-t-con-board.htm
      • 69sixpackbee
        • Jul 2014
        • 39
        Nice!!
        Thanx, Guys!
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • advant
          by advant
          02-03-2020, 12:25 AM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • netgearnetgear
          TCL 43S423 TCON OR PANEL FAULTY???
          by netgearnetgear
          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
          08-20-2025, 06:04 PM
