T-con Interchangeability LG 47LG50
  • 69sixpackbee
    • Jul 2014
    • 39
    Hi, folks,
    The T-con board on my LG 47LG50 has a part # on the sticker of 35-D020223 and it is a V420H1-C07 part #silkscreened on the board itself.
    There are many different TV manufacturers that use this V420H1-C07 board.
    Are these interchangeable possibly?
    Thanx,
    Bud
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: T-con Interchangeability LG 47LG50
    Probably not -I believe they have to be matched to the panel - just look around shop jimmy
    doing different searches and see what comes up
    That may not be the case for LG the part number seems to be specific but some may still be compatible
    https://www.youtube.com/watch?v=J1GmfoeQeP4
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Yep. Shopjimmy has the list of TVs with that panel. You need to match the number on the sticker too 35-D020223
      Looks like they have two listed the are compatible.
      http://www.shopjimmy.com/cmo-35-d020223-t-con-board.htm
      • 69sixpackbee
        • Jul 2014
        • 39
        Nice!!
        Thanx, Guys!
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • advant
          by advant
          02-03-2020, 12:25 AM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • Daren87
          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
          by Daren87
          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
          08-13-2023, 03:25 PM
        • alltvrepairs
          Lg TCon test pins for screen test
          by alltvrepairs
          i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
          Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
          Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
          Appreciate your help....
          06-13-2025, 06:33 AM
