Falcon FF32S53 turns off by itself then will not turn back on unless you wait
  • JohnML1975
    • Jul 2025
    • 25
    Dear Forum members
    I searched for a forum on this model TV and could not find so thought I would start a thread on this model and make
    I will upload some photos and share my trouble shooting steps so far
  • JohnML1975
    • Jul 2025
    • 25
    At the moment; when it faults; which can take several hours or even ten minutes. the TV turn off. then I try to turn on with remote. backlight comes on but no sound.
    • JohnML1975
      • Jul 2025
      • 25
      Using my thermal camera I note the two capacitors, to the right of the heat sink CPU CG29 and CG30 are reaching around 90 degrees celcius. other components on the board are only reaching around 50 degrees celcius. that is one obseration I have made so far
      i have removed the combination power supply and motherboard and inspected visually
      i cannot see any cracked solder joints and i cannot see signs of heat anywhere
      • JohnML1975
        • Jul 2025
        • 25
        I have had these two components disconnected and for a few hours so far the TV has been operating just fine.
        • JohnML1975
          • Jul 2025
          • 25
          These two components are the WiFi and the Bluetooth module. I had to research one of them to find out what it was.
          • JohnML1975
            • Jul 2025
            • 25
            This youtube video suggests a factory reset and just thought I would share the link
            I am yet to try this
            instead i am going to keep the bluetooth and wifi disconnected for a few days over a couple of weeks and see what happens
            link to youtube is here on the factory reset for Falcon TV
            How to Fix Ffalcon TV Keeps Turning Off – Power Supply, Firmware, and Overheat Troubleshooting Guide
            • JohnML1975
              • Jul 2025
              • 25
              I took these voltage readings with the TV on and when it was working. You can see the handwritten notes and the photo of the t-con / buffer board. I had the DMM set on DC volts and the earth probe was on the chassis
              It looks like all the voltages are correct.
              I share these incase of use to someone else or even myself as I work through this problem
                • 12146
                • U.S.
                So try the two "components" one at a time, to further track down the issue.
                  • 12146
                  • U.S.
                  Or try them one at a time and see if those caps heat up again.
                  • JohnML1975
                    • Jul 2025
                    • 25
                    Thank you. I am trying with both disconnected this weekend. Leaving TV on. Will turn on and off by remote every hour or so or whenever I think of it. If all okay this weekend. then I will try your idea of one at a time.
                    I also need to try the factory reset but will do so after I try your ideas.
                    Again, thank you
                    • tiki66
                      • Jul 2016
                      • 39
                      • Croatia
                      Here is SW for your tv (V320 if you have older):
                      https://mega.nz/file/NgoUlRQZ#Gts0X2...hMgjqHotTvKeTg
                      Try updating it and after that do a factory reset to rule out SW issue
                      • JohnML1975
                        • Jul 2025
                        • 25
                        Hello Tiki66 and thank you so much. I was looking for that and will download and try it.
                        yesterday, for ten hours I ran the TV, with bluetooth and wifi disconnected and there was no problem
                        Turned tv off, almost hourly, with the remote, waited 30 seconds and turned on. no problem
                        today, I have reconnected the bluetooth module and will test for around 12 hours today
                        • JohnML1975
                          • Jul 2025
                          • 25
                          I have reconnected the wifi and the bluetooth
                          carried out factory reset
                          following this the TV checked for updates ; it did not say it installed any but the process looked like it updated
                          now i am testing again.
                          connected to wifi and running youtube
                          will turn off with remote hourly, wait 30 seconds and turn back on as part of the checking
                          let us see how this goes
                          • Stephen
                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                            by Stephen
                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                            03-15-2024, 09:37 AM
                          • www
                            LG L192WS-BN backlight turns off after 1 second
                            by www
                            I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                            I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                            03-24-2024, 05:26 PM
                          • SCCronauer25
                            Dynex tv with model #32L200a12 turns on, but shows "please wait..." quickly...
                            by SCCronauer25
                            I am trying to fix my Dynex tv. The PSB is new and so is the Control Board, but when I turn it on, I get "please wait..." on screen, then it quickly goes black. I have the back of it off and checking voltages shows 5v standby and 2.5v supply comes on going away/into PSB/Control Board, 24v is present on PSB (getting .4v on most, if not all, backlight lines, 5v to backlight is there also), the control board's heatsink staying hot to the touch, plus the 2.5v going away/into the PSB/Control Board, gives me the impression it is on. What else should I check for?
                            07-02-2022, 02:34 PM
                          • andrhouseolly
                            Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                            by andrhouseolly
                            Hi.
                            I kindly ask you to help me solve the problem.
                            Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                            The board turns on, there is no image.
                            Read more. When the power supply is connected, the front panel indicators light up briefly.
                            When you press the power button, the button indicator lights up. The board works
                            there is no image, there is no matrix initialization, there is no image on HDMI.
                            When turned on, the fans do not spin, but when they warm up they start spinning.
                            When you turn off the button, the fans spin up to full speed for a short...
                            05-11-2024, 03:14 PM
                          • Egidio85
                            Samsung UE55F8000SZ Turns on and off immediately
                            by Egidio85
                            good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                            This defect happens continuously, hearing the classic click of the relay every time.
                            Power supply board BN44-00636B
                            disconnecting the mains and lamps from the power board always causes the same problem.
                            Is it normal that without anything connected this power supply turns on and off cyclically?
                            any suggestions on what to check?
                            thanks in advance
                            03-11-2025, 12:45 PM
