I am trying to fix my Dynex tv. The PSB is new and so is the Control Board, but when I turn it on, I get "please wait..." on screen, then it quickly goes black. I have the back of it off and checking voltages shows 5v standby and 2.5v supply comes on going away/into PSB/Control Board, 24v is present on PSB (getting .4v on most, if not all, backlight lines, 5v to backlight is there also), the control board's heatsink staying hot to the touch, plus the 2.5v going away/into the PSB/Control Board, gives me the impression it is on. What else should I check for?
Dynex tv with model #32L200a12 turns on, but shows "please wait..." quickly...
Tags: None
Re: Dynex tv with model #32L200a12 turns on, but shows "please wait..." quickly...
post good clear straight on pictures of each board and one of the whole back as to see how everything is connected, use the go advanced to post pics. -
Got it, will do.Comment
Pics of the connections and boards. I can check specific voltages if asked to. I have also checked for the voltages I get on the top two backlight lines when I power on and it reads about 12v for each before the backlight turns off. I know that it technically works other than it saying "please wait..." before the screen just goes black with no more backlight while everything stays in the "powered on" state.Attached Filesif you find these attachements useful please consider making a small donation to the site
ok start with connector x508, put your black probe on chassis ground, red probe on each pin, just probe the top to touch the metal, check each pin in standby (tv plugged in power off) take note of voltage, keep the probe where it is power tv on take note, report results, like pin 1 power-on, standby 0 volts powered on 3.3 volts, need pin label and condition in both standby and powered. Do that for each pin.Comment
good example of testing there: https://www.youtube.com/watch?v=XH9GfkGQX1IComment
x508 connector voltages (powered off vs powered on) is as follows:ok start with connector x508, put your black probe on chassis ground, red probe on each pin, just probe the top to touch the metal, check each pin in standby (tv plugged in power off) take note of voltage, keep the probe where it is power tv on take note, report results, like pin 1 power-on, standby 0 volts powered on 3.3 volts, need pin label and condition in both standby and powered. Do that for each pin.
Standby mode plugged in and powered off:
pin 1: 0.000v
pin 2: 0.033v
pin 3: 0.033v
pin 4: 0.000v
pin 5: 0.000v
pin 6: 0.020v
pin 7: 0.002v
pin 8: 5.079v
pin 9: 0.001v
pin 10: 0.005v
Powered on mode:
pin 1: -0.005v
pin 2: 11.78v
pin 3: 11.78v
pin 4: -0.007v
pin 5: -0.007v
pin 6: 2.482v
pin 7: 5.000v
pin 8: 5.057v
pin 9: 2.535v
pin 10: 4.570vComment
pin 1: Labeled "GND"x508 connector voltages (powered off vs powered on) is as follows:
pin 1: 0.000v
pin 2: 0.033v
pin 3: 0.033v
pin 4: 0.000v
pin 5: 0.000v
pin 6: 0.020v
pin 7: 0.002v
pin 8: 5.079v
pin 9: 0.001v
pin 10: 0.005v
Powered on mode:
pin 1: -0.005v
pin 2: 11.78v
pin 3: 11.78v
pin 4: -0.007v
pin 5: -0.007v
pin 6: 2.482v
pin 7: 5.000v
pin 8: 5.057v
pin 9: 2.535v
pin 10: 4.570v
pin 2: Labeled "12v"
pin 3: Labeled "12v"
pin 4: Labeled "GND"
pin 5: Labeled "GND"
pin 6: Labeled "PON"
pin 7: Labeled "5v-1"
pin 8: Labeled "5v-5"
pin 9: Labeled "PWM"
pin 10: Labeled "BON"Comment
I considered that, but, when the tv initially powers on, I see picture and backlights come on. Hence why I noted that I get the message "please wait..." then it goes black while staying on. This happens every time I power on, so, I can only assume backlight is still working.
Bad caps, possibly? ((I also noted that this is a "new-probably refurbished or taken from partly good tvs respectively" PSB and Control Board. So, I am not sure that is what the issue is. Unless there is a bad cap on another pcb behind the metal housing that everything is attached to (which I doubt, but who knows), maybe in between the metal and backlight panel where the wires go into it))Comment
Pics of inside the backlight housing area. I will try and see tomorrow, possibly, if any of the lights do not come on. I am thinking they are ok, only because there are no noticeable dark areas of the screen when it does light at power on...Pics of the connections and boards. I can check specific voltages if asked to. I have also checked for the voltages I get on the top two backlight lines when I power on and it reads about 12v for each before the backlight turns off. I know that it technically works other than it saying "please wait..." before the screen just goes black with no more backlight while everything stays in the "powered on" state.Attached Filesif you find these attachements useful please consider making a small donation to the site
ok, so you didn't waste any time and stripped it down, shows you're not lazy,
be very careful with the panel, very easy to break them, specially on bigger sets, this 32 is much easier to manage. ok go ahead and ohm out your transformers on the inverter board, measurements on all of them should be very close to each other. meter in ohm mode, ohm testing done with tv UNPLUGGED from power, video example there, not your same tv but should give you the general idea:
https://www.youtube.com/watch?v=vNIWtrEHYscComment
Well, I guess moving it around to keep away from pets, having no rigidity, plus with my inability to keep it from twisting too much as I move it from one place to the other, has apparently taken its toll on one of the lights unfortunately, one end of the top bulb broke, right at the beginning of the blackened area of the bulb.
I still checked the coils and they seemed ok, all reading about 0.1-0.2 ohms.
However, it looks like this repair is a bust, as I don't think I will be able to find a bulb like the one that is needed. I am curious to see if the bulbs could just be replaced with LED's instead, but I am not sure if that would be a viable option, at least not without figuring out a way to drive them...Comment
it can be converted to led pretty cheaply, aliexpress sells kits for not much, probably ebay too.Comment
I meant to say ebay has them too but not as much to choose from as aliexpess.Comment
by taslanHello everyone,
as stated in the title, my surface 7 pro wont boot anymore.
When i press the power button it shows the square windows logo for a second and immediately turtns off again.
I dont even have a chance to get into bios or boot from usb.
While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
Bought it directly from microsoft and used it now and then and only... -
by JohnML1975Dear Forum members
I searched for a forum on this model TV and could not find so thought I would start a thread on this model and make
I will upload some photos and share my trouble shooting steps so far8 Photos -
by StephenMacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
by mnciks11Hello guys, i need your help fellow brothers
Im diagnosing a Lenovo G80-50 laptop
ACLU3/ACLU4
Rev : 1.0
when you press the power button, the LED power light turns On and quickly shuts down, no display, fan spins a sec and stop. I haven’t seen any short so far.
PU908 (CPU POWER CORE CHIP) is getting hot the moment you press the power button, the laptop turns off very fast, i changed PU908, still im getting same problem, on output side of the 2 cpu power supply coil i get 1.6v and then goes away as soon as the laptop turns off, still the... -
by wwwI am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....-
- Loading...
