Hisense 55AS6G screen double sided tape required
  • alltvrepairs
    • Jan 2014
    • 256
    • Malta
    I need to replace the LEDs of this TV. The screen is glued with double sided tape. This video shows the proceudre required.
    I need a source for this type of double sided tape adhesive please.
    https://www.youtube.com/watch?v=bN6g...nel=QUADRA-NET
    Tks!
  • howardc64
    • Jun 2017
    • 656
    Tks!
    I got some before from aliexpress that seems to work pretty well. No idea if genuine. Search "3M 5952 4mm" Probably good to check the width after cutting the screen open.
    On no bezel LCD panels, here are some dis/reassembly notes
    • 2012+ iMacs also use double sided tape to glue on screen. A plastic pizza cutting wheel tool is used to cut open the iMac screen. This is probably more desirable than a non rolling cutting tool to minimize producing debris on the back (clean) side of the LCD panel that has to be ultra clean.
    • I took the time to painstakingly remove the old tape from the backside of LCD panel (wear nitrile gloves to keep the LCD clean). This exposes this clean side for long periods with more chance to collect debris. Debris can only be discovered after nearly full assembly to power on TV to show a white screen to examine for debris. I unfortunately cracked the LCD while tilting the LCD from one corner trying to use sticky tape to remove the debris. Ideally, use compressed air to blow clean the clean side prior to assembly. Also avoid sticking on the LCD prior to checking for debris. If require 2nd LCD removal to clean debris, use something like masking tape to mark the location in front of the LCD to locate the debris then remove LCD panel completely for cleaning. Mine cracked because I tried tilting the LCD as a short cut to get to the debris. LCD probably wouldn't have cracked if I had a 2nd person to lift and tilt the LCD from both corners.
    • Also note LCD panel's strength is deceiving. The 2mm+ thickness is mostly a strength providing glass. The actual LCD is patterned onto a super thin glass that is glued to this thicker glass. This ultra thin glass is what cracks and not the thicker glass.
    • EazyBone
      • Jun 2023
      • 1364
      • United states
      Good advice for fixing the TV and the debris.
      My advice is just forget about it lol. The headache that this type of TV repair isn't worth it. Debris gets everywhere from having to cut the tape to get the screen off. The tape is black and so is the screen and it sticks really well to the TV after cutting. Impossible to see until you put it back together. It can definitely be done because I have done it.. but it's not much worth it. But howards tips are very nice.
      Since it seems your job is repair tvs good luck! Ali Express or eBay has the tape
      • alltvrepairs
        • Jan 2014
        • 256
        • Malta
        Lool, I think this is a good advice! I will try to get rid of it politely as cannot see a good end for both of us!
        • EazyBone
          • Jun 2023
          • 1364
          • United states
          In my experience it's not worth the headache. I can do backlights all day no problem. Once I have this TV with the tape you have to cut .. it's always a pain in the ass. Debris behind the screen makes you feel unprofessional so you have to fix it.. and then it takes 2x longer then you wanted. I'd say good idea.
          • Unspun01
            • Jun 2011
            • 349
            I have repaired a few Hisense "no bezel" LED TVs. These are definitely a real pain to work on. I charge extra for repairing these since they are so much extra work.
            To remove the double-sided sticky tape, I use a sharp box cutter (X-acto) blade and gently cut by moving blade back and forth. This minimizes small debris by not totally disintegrating the foam into smaller pieces. Do not use too long of a blade since you do not want to scratch the delicate LCD panel on the inside.
            Once LCD and frame are separated, the factory adhesive rolls off the panel and frame pretty easily by simply using your finger tip in a forward motion (like pressing a button repeatedly with your index finger) and once you get it started, it kinda rolls together into a small ball. Yes, this will leave some finger prints and adhesive residue on the outer edges of the LCD panel, but use 99% isopropyl alcohol (ask for it at your pharmacy, it is usually behind counter).
            This adhesive tape is special. It is actually a double-sided foam that is quite thin. No doubt you have already realized it's pretty flexible. The foam permits a little bit of movement between the panel and the frame. I have tried regular double-sided tape but while it stays stuck to the LCD panel, it almost never sticks well to the frame coating and even though the TV went back together perfectly, after a few weeks I noticed the panel coming off the frame at the corners. This could have been catastrophic if the panel completely detached and fell forward causing it to crack. Maybe 3M makes a better product than I used, but my advice is to be careful.
            My solution was to re-clean the surfaces and re-apply the double-sided tape, AND ALSO use a small amount of black RTV silicone (from your auto parts store) at the upper left and right corners and even at a few spots along the top and sides of the panel (between panel and frame) to ensure the panel doesn't detach from the frame. While fresh, the RTV can be wiped clean and is practically invisible so you or your customer will never notice it.
            CAUTION: If you decide to use RTV, be very careful how much you use. If you use too much, it will squeeze outward and inward as you apply pressure and could appear in the corner during viewing if it covers any of the pixel area. Anything squeezed outward is not an issue since it can be wiped away.
            As stated, this is very good for long term repair where you won't have to worry about the panel coming off due to crappy tape. Even good tapes can fail over time as they warm up during use and start to stretch. The RTV provides a very good bond, and is easily cut with sharp blade if you ever need to re-open the TV.
            Perform this work on a flat surface with the TV supported appropriately from the back side so that there is no twisting of the frame. If it is not perfectly level or flat when you re attach the panel, some forces will be applied when TV is put back to vertical on it's stand and this will work against the adhesive.
            Some other thin foam adhesives might work perfectly, but I did not have any to try at the time.
            Best of luck.
            • alltvrepairs
              • Jan 2014
              • 256
              • Malta
              Best of luck.
              I have returned the TV as the customer seemed not happy or convinced about the risk involved. So am sorry I cannot give any good or bad feedback here. Tks for the long explanation and caution! Will be useful in the future for sure!
              • EazyBone
                • Jun 2023
                • 1364
                • United states
                Yea I wouldn't even touch it for a customer if it was bezel less. Too much chance for error. If you had it for free.. maybe.
                • x_orange90_x
                  • May 2015
                  • 765
                  I am resurrecting this post because I am going through this same thing and also I have a tip to add. I likewise have a 55" Hisense bezel-less that I trash picked last week. Of course it needs backlights, don't they all? 🙄
                  I did this same repair on a Toshiba earlier this year and while it went seemingly smooth, after selling the tv and the customer wall mounting it, the tape wasn't holding well so the panel sagged and damaged the bottom corners rendering it useless. I did use 3M double sided electronics foam mounting tape. I DID NOT however, use adhesion promotor or tape primer. Neither did I can the edges of the panel with alcohol (this I think is the true cause of the new tape not bonding to the glass).
                  Anyway, as for my tip I mentioned. Instead of separating the screen from the frame with a knife or other potentially damaging instrument... Use fishing line. Cut a 4-5ft piece of fishing line and starting at the corner of the screen, move the line back and forth with a slight backward force. It easily cuts through the adhesive without risking any damage to the panel.
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • Storyteller12
                    Double Sided Tape
                    by Storyteller12
                    Just curious what double sided tape everyone uses on the tv screen/ panel when replacing backlights on models like the Samsung ks8000 and mu9000.
                    I replaced backlights on a curved model ks8500 and it's started to come apart with the tape I used. Have to redo it now but not sure what's the best tape so I don't have this problem again
                    03-21-2022, 07:53 PM
                  • howardc64
                    Replaced HiSense 75H6570G backlight
                    by howardc64
                    TV has 2 strings of LED backlight. 1 string had 1x LED failure. Replaced all LED light bar (thought about replacing just 1 bar but new bar LED color more white compared to old)
                    The large screen and HiSense reflector paper assembly presented some challenges over the smaller screens.
                    - 75" TV is huge, need 2x large work surface (1 for TV, 1 for LCD panel)
                    - White reflector paper in the tub is secured by 10 columns and 1 row (on top the tub) of double sided sticky tape. Took awhile (need to go slow to avoid/minimize damage) to remove with minimal damage.
                    05-19-2023, 01:38 AM
                  • RetroComputingGrotto
                    IBM LTO 7 Tape Drive - Dust Sensors??
                    by RetroComputingGrotto
                    I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                    I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                    09-19-2024, 01:54 AM
                  • jason123
                    Hisense 65R6E3 double-image / horizontal strips - TCON?
                    by jason123
                    Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                    07-19-2025, 08:07 AM
