Philips 65PUS8518/12 distorted image after main board replacement
  • tuner2000i
    • Jun 2018
    • 26
    • Romania
    hello everyone,
    I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
    The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
    I am able to access 2 menus, 062596 + OK and Home+1999+backspace to enter factory menu. I am however unable to change the Panel ID which is set to 2. I tried all buttons and I can not change that value. Also I tried 062598 + Home + 016 and 062598 + Menu + 016 and nothing happens.
    I also replaced three 8 pin small chips on the board which I thought are eeprom's hoping that the settings will also update but with no luck. I am not sure where these settings are stored. If they are in the nand I do not have a reballing machine to do it anymore.
    I searched the forum for NVM file and i could not find any. I attached the NVM dump from the 55PUS8518 board if that helps.
    Any help will be kindly appreciated.
  • tuner2000i
    • Jun 2018
    • 26
    • Romania
    I found some SM which is not from this model but it said the code 062598 + Home + 016 should be entered from a normal RC remote. The original tv remote is both IR and bluetooth. Even though I disabled the bluetooth i tried today with a remote which is IR only again without success.
    • lotas
      • Jan 2016
      • 4555
      • Russia
      After software updates this method no longer works, the only option is to find NVM for your TPM23.1E LA chassis and for your model and panel or look for a motherboard for your panel.
      • tuner2000i
        • Jun 2018
        • 26
        • Romania
        thanks for the reply lotas, at least i am not wasting my time with the remote buttons anymore. I found another board but before buying, does anyone here have this NVM, if yes please share even in DM. I was not able to find anywhere NVM's newer than 2019
        • lotas
          • Jan 2016
          • 4555
          • Russia
          Unfortunately, there isn't one, but if there was, I would help you.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4298
            • Italy - Milan
            Which are the keys you press to navigate to menus in service?
            • tuner2000i
              • Jun 2018
              • 26
              • Romania
              I pressed Home+1999+backspace. I fixed the TV, i managed to obtain the NVM file from a local tv service. if anyone needs it, send me a DM
              • lotas
                • Jan 2016
                • 4555
                • Russia
                Yes, you found the NVM file quickly, you are lucky.
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                • JDC
                  (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                  by JDC
                  ONN 100012588
                  Issue: No Power, Then Rebooting After Main Board Change
                  Short answer: replace main board and power board
                  Technical answer: replace main board and Q306 & Q307 on power board.
                  Long answer:
                  TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                  07-15-2022, 07:39 AM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • cheeky2
                  by cheeky2
                  05-25-2024, 03:27 AM
