TCL U55C7006 TV does not start
  • janos6662000
    • Mar 2015
    • 33
    • Romania
    Hello
    I received from a friend from Norway a faulty TCL U55C7006 TV
    TV had a white power led on when powered on, later the LED went off, but no picture.
    Initially i thought that it has a bad backlight. I tested the led strips with a tester but they proved good. I also checked the screen with a powerful flashlight, but no sign of any signal on screen.
    I made some research and i discovered that the TV is an Android TV and the fault i have is often connected to a firmware problem.
    I downloaded some firmware images and made some trials.
    I tried with 3 different USB sticks, size ranging from 2-8GB, formatted FAT32 (in the end i also tried FAT16) and different firmware images. I used USB sticks with leds to check activity.
    When i power on the TV, LED shortly lights on, then off.
    Sunday i forgot the TV on and i left. When i got home, i saw that the TV has backlight. I flipped it over and i saw some pinkish garbage on screen. I switched off the TV and back on.
    This time it had the TCL logo, later animated, then the Android logo and eventually it booted normally. I got a screen saying (in norvegian language), that no device is connected to HDMI3.
    This proved that none of my firmware writing attempts was successful. but also the fact that the display itself is OK.
    Tried to enter some menu with the joystick, nothing happened.
    I thought that probably the joystick is faulty. I programmed a universal remote for this TV, when i got back, the TV did nothing with the remote.
    I switched it off and back on, but since then only the pinkish garbage, sometimes the TCL logo, but TV does not boot.
    I obtained the service manual but until now i didn't find any abnormal voltages.
    As i see it now, one secondary voltage does not work correctly and stabilizes in time. The motherboard is powered only by 12V from the power supply. That voltage does not vary.
    Of course, when i don't have backlight, the BL_ON voltage is missing. Other than that, i didn't see any differences yet.
    Please advise.
    • 12206
    • U.S.
    Can you post some clear straight on pictures of each board and one of the whole back as to see how everything is connected. And one of the pinkish garbage.
    • janos6662000
      • Mar 2015
      • 33
      • Romania
      Here are some pictures.
      Pink stuff is not always the same, i even saw a few times the TCL log, on normal picture.
      Since then i never left it to warm for hours, so i never got sunday's result again.
      • tiki66
        • Jul 2016
        • 39
        • Croatia
        Here is SW for your TV:
        https://mega.nz/file/wtYWHYCT#6iktYW...Jq_Pjg6hjSpxnw
        (V8-T658T01-LF1R820_Test_Version.zip)
        Download SW and unzip it. Put Upgrade.pkg directly on root of usb stick. Stick must be FAT32 formatted.
        Unplug tv, insert stick, press power button ON TV and keep it holding while plugging in tv in socket. Upgrade procedure should start.
          • 12206
          • U.S.
          Check the side panel for the reset recess, use a paperclip or the like to press it, hold for about 30 seconds or til you see the front indicator light up a little, release it then try to turn tv on as normal.
          • janos6662000
            • Mar 2015
            • 33
            • Romania
            Hello tiki66
            Thank you for the firmware.
            I tried, but unfortunately no success. I still think that this is a hardware problem. Even the P_ON signal appears after a looooong time (10 of minutes.)
            • janos6662000
              • Mar 2015
              • 33
              • Romania
              Hello nomoresonys
              Thanks, but this mainboard doesn't have a reset button, i checked carefully.
                • 12206
                • U.S.
                Could be an hdmi problem, maybe try heating the hdmi chip for a couple minutes with a hair dryer then try tv, see if it does anything different. For this test just use a hairdryer NOT a heatgun.
                • howardc64
                  • Jun 2017
                  • 627
                  I've not seen this model but since its low end brand (TCL) and Google TV, maybe likely it suffered the eMMC failure so common for Google TVs?
                  Here is a HiSense Google TV I debugged with this problem ( link )
                  Nick's TV has a ton of videos on SONY's Google TV with eMMC failure ( link )
                  Low end brand like HiSense also puts HDCP, Netflix and streaming app keys in the dead eMMC so even if new eMMC is firmware installed. Still lost all keys so streaming and HDMI won't work. SONY was smart enough to put the security keys in separate memory.
                  If replacement main board is expensive and mostly out of stock, it usually suggest the typical high Google TV eMMC failure and only repair unfortunately is board replacement if can't rebuild eMMC and/or keys are in the dead eMMC.
                  I don't know why Google TV have such high eMMC failure rate. Low end TVs likely use lower capacity eMMC (faster wear) and Google TV may have some abusive level of flash memory writes. For example, excessive logging which is fairly common computer developer approach. I have a 2013 Tesla Model S and they also ruined the entertainment console's eMMC within 4-5 years by over logging.
                    • 12206
                    • U.S.
                    Any update on this?
                    • janos6662000
                      • Mar 2015
                      • 33
                      • Romania
                      Any update on this?
                      Sorry, i was a little busy, will get back adter i check.
                      • janos6662000
                        • Mar 2015
                        • 33
                        • Romania
                        Hello
                        Could you advise which could be the hdmi chip? And what temperature to use for heating? Instead of a hair dryer, i would use a hat air gun, but it has digital control and i can set any temperature starting from room temperature. I trust this one better.
                          • 12206
                          • U.S.
                          Looks like it's under the heatsink., can you carefully remove the heatsink?
                          • janos6662000
                            • Mar 2015
                            • 33
                            • Romania
                            Sure, i will remove the heatsink and pot a picture.
                            • janos6662000
                              • Mar 2015
                              • 33
                              • Romania
                              Hi, I'm back.
                              Unfortunately, nothing of this kind under the heatsink
                                • 12206
                                • U.S.
                                You can follow the traces from the hdmi ports to where they go, looks like they're going to your mediatek chip. Guessing you need a replacement board or maybe send it off to Nick's. They can diagnose the board, replace the chip if needed. Can try one of the diy reflows on youtube but risk ruining the board. To just try the test hit it with only the hairdryer for a minute or two, then try it, see if you get a display. Don't run it too long without the heatsink on tho.
                                  • 12206
                                  • U.S.
                                  Check Howardc64 link in post #9 to Nick's, he's done a thousand sonys, he knows his stuff.
                                    • 12206
                                    • U.S.
                                    Nick's shows some testing of the little mlc caps near the chips. It's a way of knowing if the main chip is faulty/bad.
                                    • TheUser
                                      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                      by TheUser
                                      Hello to everyone ,
                                      This is my first post here, and i would like to share with you a small story in case you can help me.
                                      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                      02-10-2024, 02:07 PM
                                    • zklgfs
                                      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                      by zklgfs
                                      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                      08-11-2025, 02:14 PM
                                    • gurj1979
                                      Ubiquiti firmware help. US-8-150W POE
                                      by gurj1979
                                      Hi guys.
                                      I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                                      Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                                      So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                                      Got New chip and writes good.
                                      THE PROBLEM...
                                      It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                                      Does anyone have a Good Firmware I can have?...
                                      07-22-2024, 05:13 PM
                                    • wattage
                                      AOC AG493UCX 49-inch monitor - Firmware request
                                      by wattage
                                      Hello Badcaps Community,
                                      The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                      07-13-2025, 04:41 PM
                                    • sikocan
                                      NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
                                      by sikocan
                                      I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
                                      However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
                                      01-11-2024, 01:47 AM
