TCL U55C7006 TV does not start
  • janos6662000
    • Mar 2015
    • 24
    • Romania
    Hello
    I received from a friend from Norway a faulty TCL U55C7006 TV
    TV had a white power led on when powered on, later the LED went off, but no picture.
    Initially i thought that it has a bad backlight. I tested the led strips with a tester but they proved good. I also checked the screen with a powerful flashlight, but no sign of any signal on screen.
    I made some research and i discovered that the TV is an Android TV and the fault i have is often connected to a firmware problem.
    I downloaded some firmware images and made some trials.
    I tried with 3 different USB sticks, size ranging from 2-8GB, formatted FAT32 (in the end i also tried FAT16) and different firmware images. I used USB sticks with leds to check activity.
    When i power on the TV, LED shortly lights on, then off.
    Sunday i forgot the TV on and i left. When i got home, i saw that the TV has backlight. I flipped it over and i saw some pinkish garbage on screen. I switched off the TV and back on.
    This time it had the TCL logo, later animated, then the Android logo and eventually it booted normally. I got a screen saying (in norvegian language), that no device is connected to HDMI3.
    This proved that none of my firmware writing attempts was successful. but also the fact that the display itself is OK.
    Tried to enter some menu with the joystick, nothing happened.
    I thought that probably the joystick is faulty. I programmed a universal remote for this TV, when i got back, the TV did nothing with the remote.
    I switched it off and back on, but since then only the pinkish garbage, sometimes the TCL logo, but TV does not boot.
    I obtained the service manual but until now i didn't find any abnormal voltages.
    As i see it now, one secondary voltage does not work correctly and stabilizes in time. The motherboard is powered only by 12V from the power supply. That voltage does not vary.
    Of course, when i don't have backlight, the BL_ON voltage is missing. Other than that, i didn't see any differences yet.
    Please advise.
    • 12094
    • U.S.
    Can you post some clear straight on pictures of each board and one of the whole back as to see how everything is connected. And one of the pinkish garbage.
    • janos6662000
      • Mar 2015
      • 24
      • Romania
      Here are some pictures.
      Pink stuff is not always the same, i even saw a few times the TCL log, on normal picture.
      Since then i never left it to warm for hours, so i never got sunday's result again.
      • tiki66
        • Jul 2016
        • 35
        • Croatia
        Here is SW for your TV:
        https://mega.nz/file/wtYWHYCT#6iktYW...Jq_Pjg6hjSpxnw
        (V8-T658T01-LF1R820_Test_Version.zip)
        Download SW and unzip it. Put Upgrade.pkg directly on root of usb stick. Stick must be FAT32 formatted.
        Unplug tv, insert stick, press power button ON TV and keep it holding while plugging in tv in socket. Upgrade procedure should start.
          • 12094
          • U.S.
          Check the side panel for the reset recess, use a paperclip or the like to press it, hold for about 30 seconds or til you see the front indicator light up a little, release it then try to turn tv on as normal.
          • janos6662000
            • Mar 2015
            • 24
            • Romania
            Hello tiki66
            Thank you for the firmware.
            I tried, but unfortunately no success. I still think that this is a hardware problem. Even the P_ON signal appears after a looooong time (10 of minutes.)
            • janos6662000
              • Mar 2015
              • 24
              • Romania
              Hello nomoresonys
              Thanks, but this mainboard doesn't have a reset button, i checked carefully.
                • 12094
                • U.S.
                Could be an hdmi problem, maybe try heating the hdmi chip for a couple minutes with a hair dryer then try tv, see if it does anything different. For this test just use a hairdryer NOT a heatgun.
                • howardc64
                  • Jun 2017
                  • 579
                  I've not seen this model but since its low end brand (TCL) and Google TV, maybe likely it suffered the eMMC failure so common for Google TVs?
                  Here is a HiSense Google TV I debugged with this problem ( link )
                  Nick's TV has a ton of videos on SONY's Google TV with eMMC failure ( link )
                  Low end brand like HiSense also puts HDCP, Netflix and streaming app keys in the dead eMMC so even if new eMMC is firmware installed. Still lost all keys so streaming and HDMI won't work. SONY was smart enough to put the security keys in separate memory.
                  If replacement main board is expensive and mostly out of stock, it usually suggest the typical high Google TV eMMC failure and only repair unfortunately is board replacement if can't rebuild eMMC and/or keys are in the dead eMMC.
                  I don't know why Google TV have such high eMMC failure rate. Low end TVs likely use lower capacity eMMC (faster wear) and Google TV may have some abusive level of flash memory writes. For example, excessive logging which is fairly common computer developer approach. I have a 2013 Tesla Model S and they also ruined the entertainment console's eMMC within 4-5 years by over logging.
                    • 12094
                    • U.S.
                    Any update on this?
                    • janos6662000
                      • Mar 2015
                      • 24
                      • Romania
                      Any update on this?
                      Sorry, i was a little busy, will get back adter i check.
                      • TheUser
                        Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                        by TheUser
                        Hello to everyone ,
                        This is my first post here, and i would like to share with you a small story in case you can help me.
                        Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                        All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                        I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                        02-10-2024, 02:07 PM
                      • gurj1979
                        Ubiquiti firmware help. US-8-150W POE
                        by gurj1979
                        Hi guys.
                        I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                        Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                        So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                        Got New chip and writes good.
                        THE PROBLEM...
                        It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                        Does anyone have a Good Firmware I can have?...
                        07-22-2024, 05:13 PM
                      • sikocan
                        NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
                        by sikocan
                        I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
                        However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
                        01-11-2024, 01:47 AM
                      • skynetto
                        MSI Z590 MS-7D07 rev 2.1 EC Firmware
                        by skynetto
                        Hello there.
                        I have this mainboard (MSI Z590 Gaming edge - MS-7D07 rev 2.1) with these symptoms.
                        1. SIO_3VA ON
                        2. ATX_5VSB ON
                        3. 3VDSW ON
                        4. Mainboard stucked in Deep_S5 state
                        Problem:
                        RSMRST Incative. (Obviosly everything dead)
                        Tried just for fun to update the BIOS with its Bios flashback function (Push button and USB stick with bios in it).
                        Main Bios restored succesfully.
                        When updating Bios all the voltages comes on except PCH which is not needed.
                        EC Controller: NCT6687D-M
                        External SIO Firmware...
                        03-17-2023, 10:30 AM
                        ME Firmware Cleaning Guide
                        by SMDFlea
                        Here`s a quick ME Firmware cleaning guide.
                        The guide is basic,its main goal is to show you how to use intel FIT,its highly recommended that you all follow the guide posted at win-raid
                        (The attached FIT version is 11, if your ME Firmware (FW) is not 11.0.*.* follow the win-raid guide. Use the tools version for your ME FW, for example: ME System Tools v9.1 For systems running ME v9.0 - v9.1)
                        A video,software (intel FIT) and practice bios are all included. I`ll post a better video and more advanced guide at a later date.
                        1. Open the...
                        09-09-2020, 09:10 AM
