Bush ly2211wcw tv/dvd combi hd ready tv
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Just pick this up local freecycle in original box has stand but no remote control set was stuck in standby red led on constant c36 and c36 in psu was bad both are 1000uf 16volts i relaced with panasonic replacements tv section seems to work great just the dvd section wont spin up. Ive cleaned the laser etc still wont spin ive read on various posts and it seems the motor that spins the disk maybe the issue but to be honest im not going to bother repairing the drive as you can always use a dvd player via scart etc.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Bush ly2211wcw tv/dvd combi hd ready tv
    Good find!! - did well to be "chosen" Good fix
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      Yes not bad ive got three of these 22in tv/dvd fixed here now all free cycle ones 2 boxed a toshiba (works perfect) a warfdale one (dvd drive ok just needs a remote) and this bush one (needs a remote and dvd drive) but will be ok as a monitor/freeview tv i guess much on your freecycle/gumtree selldoor?
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        Hi guys need a bit of advice ive given this set to a friend hes noticed when you first turn the set on there is no sound for about 20 seconds then it just comes on ok (they have also said it can loose sound after nt set period of times) ive tried to do a factory reset i can get into the setting but no matter what i press on the remote it wont factory reset.Nothing happens at all now im using a replacement remote for this set and it does work everything else it should do. The main board is a HAIER MST9E19B. I will pick my digital camera back up tmorrow as someone borrowed it ages ago and try to take some pictures of the board. I have checked the few power supply votages and they are what they should be (printed on psu) so i doubt it its that but there are about three voltage regulators that are showing signs of heat stress on the main av board pcb i will try to get the votages from them in the fault and working conditions but as anyone who has worked on these sets know the screen is in the way on these and the boards are screwn in upside down.
        • countrywill
          • Nov 2015
          Hi How do I upload a service manual to your site?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Select "Go Advanced" in the box below the post you are writing where you can now add attachments
            • countrywill
              • Nov 2015
              Hi I found and attached a service manual for this set. The one I have was stuck in standby i replaced 2 caps 1000uf 16v on power board and got picture working but have no sound I got a AV board off ebay but it only showed wide colored vertical lines on screen I came to the conclusion that the decoder chip had gone so I have now bought another AV board again from ebay and hope it works when it arrives
              • FlailingEngineer
                Help with Bush Tv (Vestel 17mb95m Mainboard)
                by FlailingEngineer
                Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                05-31-2023, 06:52 AM
              • tyler123456
                Need help identifying an IC chip on a Bush DAB radio (BD-1801)
                by tyler123456
                Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
                I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
                I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
                Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
                Anyone...
                08-16-2024, 12:51 PM
              • Johnny.p
                Bush WI-1810 Internet Radio
                by Johnny.p
                I recently bought an internet radio Bush WI-1810, it came with a power supply that when plugged in promptly damaged the radio. I discovered too late that the radio was 6v and the supplied adaptor was 12v. The radio still powers on but the wifi is not working. I have attached a few pictures- Image 2 showing the board with damaged component top right labelled U8. There are several other similar components like U9 (image 3) that I'm wondering could be a replacement.
                U9 has a code on it S5EJI- I have searched several smd code sites and the nearest I can find is for a mark of S5E -listing shows...
                11-25-2023, 04:18 AM
              • sikocan
                Lenovo X1 Carbon 9th Gen Black Screen
                by sikocan
                I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                SN: PF3G1REP
                MODEL: 20KW-00J1AU
                PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                06-24-2025, 09:01 PM
              • razzer05
                Bush LE50GY15M - Firmware needed, Please!
                by razzer05
                I did a silly thing and tried to update the tv (Bush LE50GY15M) with a "allupgrade_6308rtbm.bin" off the internet with the same board name "T.MS6308.U701" and it now no longer works.
                I have researched quite a bit since Fridays messup, I've gathered a bit of information and tried multiple "allupgrade_6308rtbm.bin" files off the internet to try and fix it.
                The information I've come up with:
                A possible clone of "SEIKI SE50UO01UK" with a Bush Logo
                The board is as mentioned: "T.MS6308.U701"...
                09-23-2020, 03:43 PM
