Bush LE50GY15M - Firmware needed, Please!
  • razzer05
    • Sep 2020
    • uk
    I did a silly thing and tried to update the tv (Bush LE50GY15M) with a "allupgrade_6308rtbm.bin" off the internet with the same board name "T.MS6308.U701" and it now no longer works.
    I have researched quite a bit since Fridays messup, I've gathered a bit of information and tried multiple "allupgrade_6308rtbm.bin" files off the internet to try and fix it.
    The information I've come up with:
    A possible clone of "SEIKI SE50UO01UK" with a Bush Logo
    The board is as mentioned: "T.MS6308.U701"
    The binary I believe I am looking for and seems to work at upgrading the tv is: "allupgrade_6308rtbm.bin"
    A sticker with the following details:
    version:20150902_105240
    2015-09-02 10 52:40
    sy15348
    07N21 15090 00264
    Another sticker:
    b15082972-0aa00070
    t500qvn02. 0 RoHS
    Rang bush and contacted UMC but to no avail sadly
    Any help appreciated!
  • petehall347
    • Jan 2015
    • 4449
    Re: Bush LE50GY15M - Firmware needed, Please!
    umc dont have then ?
    • razzer05
      • Sep 2020
      • uk
      Unfortunately they replied:
      Good Afternoon
      Many thanks for your email
      Unfortunately this is not one of the model we support Please contact your retailer for further assistance
      Kind Regards
      Aimee B
      UMC Freshdesk Agent
      • razzer05
        • Sep 2020
        • uk
        Anyone have any ideas of reset options?
        Websites that might be helpful?
        Versions of software that might be for another tv that could work on this one?
        If this tv has a different name / badge anywhere else?
        Any hardware I could easily replace?
        any help woulld be appreciated.
        thank you!
        • stav242
          BUSH DLED43IHDHDRS 17MB130S Firmware needed
          by stav242
          i have a BUSH DLED43IHDHDRS.
          the MB - 17MB130S is not booting - it did once then wont boot again.
          Suspect its the corrupt firmware issue.
          Where can i find the correct firmware for this model ?
          11-02-2022, 03:39 AM
        • Daniel Larsson
          Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
          by Daniel Larsson
          My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
          I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
          During these seconds the function button is not working...
          08-13-2025, 10:29 AM
        • EduCabral
          [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
          by EduCabral
          I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
          While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
          🔧 Details:
          • Model: YT-M06
          • Interface: Pioneer 1
          • MCU: Fujitsu MB89F202
          • Goal: Find a valid .bin firmware file or memory dump from a working unit
          I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
          07-15-2025, 12:26 AM
        • Daniel Larsson
          Firmware file for Marantz NR1501 needed
          by Daniel Larsson
          I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
          After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
          The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
          The content of these seems to be useless as far...
          05-23-2025, 04:11 AM
        • jorpec
          Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
          by jorpec
          Hi, all
          I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
          10-17-2025, 03:51 AM
