VIZIO VX42LHDTV10A...no sound
  • geronimoejoe
    • Aug 2013
    • 5
    I have replaced the output ic (U31) but I still have nothing. All else works fine. I have tried to trace down the audio path, but the print is really a joke. I have Vcc on the 2 inputs from an outline of the IC (TDA8946AJ). I have nothing on the scope at the L/R inputs, but I can touch the inputs using the old wet-finger method, and I get a hum, so it seems that the IC is working. .....one thought, though; there is a regulator Q27 that reads:
    I=11.58V
    o=12.2V
    Adj.=12.2V
    I need to work on my crossing/ subbing skills, but I can't find this part number anywhere on the net. The number on this reg. is C5886. If anyone could help, it would be appreciated. I just can't seem to get anywhere with this one. I know the voltages on this regulator are not right, but I don't know how to proceed with the toilet-paper schematics from Vizio.
    Also, I know some of these used a separate power supply for the audio, but this one doesn't have a stand-alone smps unless someone b4 me has really got me and good!
    TIA
    Joe's TV & APPL.
    7333 US HWY 190W
    Newton, TX 75966
    (409) 384-3325 home & shop
    (409) 489-5001 cell
    geronimoejoe@gmail.com
    Re: VIZIO VX42LHDTV10A...no sound
    Do you get Audio output at the Red and White RCA jacks? Can we also see the pictures of your main board and the Q27?
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • ggil44
      Vizio M65-E0 No Picture, No Sound
      by ggil44
      Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
      09-03-2024, 08:30 PM
    • LEECH666
      Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
      by LEECH666
      Good day ladies and gentleman!
      I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
      This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
      I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
      01-19-2024, 05:46 PM
    • shelby5041
      vizio d40f-j09 no pic no sound standby always clear
      by shelby5041
      hi
      anybody have experience with this model tv
      07-19-2025, 06:58 AM
    • ajshoe
      vizio E60-E3 backlights, sound, no video
      by ajshoe
      Have a free Vizio E60-E3 pickup - sound and backlights work. set turns on and stays on for a period then cycles off and back on. NO VIDEO. If I remove left side (from front of TV) of TCON cable - set has pic on right side (from front of TV) with white screen on left side. With right side TCON cable disconnected - no pic on either side.
      Does this mean remove right side (from front of TV) tabs ?
      Like a second opinion before possibly destroying set....
      04-07-2023, 01:59 PM
