Okay guys ill try to make this short. I bought a 46in sony from a pawn shop.. I knew it wasn't working but got it cheap.. I plugged it in nothing happened no led light no nothing so first I looked for the schematics and found out the mainboard was defected so I found one put it in and it turned on for bout 5 sec backlight came on. Then all of a sudden it shut down and the standby light started blinking twice.. So I looked at the schematic it say 2 blinks mean its a OVP(overage voltage protection)problem. From my knowledge ovp has to do with the power ic in the power board so I changed the power ic nothing happen so I just decided to buy another power board and still nothing happen im getting frustrated.. when I bought the mainboard I knew it needs a firmware update I have it on a usb stick but cant get the tv to turn on to recognize it...Guys I have 2 power boards and 2 mainboards (in this tv its a G board and a B board ) I do believe the power board is fine I think its a firmware problem but I cant get it to recognize the usb please help anybody
sony bravio kdl-46ex723
Re: sony bravio kdl-46ex723
what happens when you unplug the Tcon board and power up?Proud owner of dozens of broken TV's and many,many,many boards.
Our website and passion:http://hollenhundshepherds.com/ -
Since it won't start up don't you have to force the update somehow on these? I forget how it's done but on some other Sony models I remember it has to be on a MemoryStick card and you had to hold some key down while powering up. Sorry can't help moreComment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by delpiero3Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
Nevertheless, let's say, i don't come as a total beginner.
I have this old laptop, which suit perfectly my needs, with the... - Loading...
