sony bravio kdl-46ex723
  • drp102
    • Apr 2014
    • 9
    • united states
    Okay guys ill try to make this short. I bought a 46in sony from a pawn shop.. I knew it wasn't working but got it cheap.. I plugged it in nothing happened no led light no nothing so first I looked for the schematics and found out the mainboard was defected so I found one put it in and it turned on for bout 5 sec backlight came on. Then all of a sudden it shut down and the standby light started blinking twice.. So I looked at the schematic it say 2 blinks mean its a OVP(overage voltage protection)problem. From my knowledge ovp has to do with the power ic in the power board so I changed the power ic nothing happen so I just decided to buy another power board and still nothing happen im getting frustrated.. when I bought the mainboard I knew it needs a firmware update I have it on a usb stick but cant get the tv to turn on to recognize it...Guys I have 2 power boards and 2 mainboards (in this tv its a G board and a B board ) I do believe the power board is fine I think its a firmware problem but I cant get it to recognize the usb please help anybody
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: sony bravio kdl-46ex723
    what happens when you unplug the Tcon board and power up?
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • Clydeuk
      • Jan 2012
      • 193
      Since it won't start up don't you have to force the update somehow on these? I forget how it's done but on some other Sony models I remember it has to be on a MemoryStick card and you had to hold some key down while powering up. Sorry can't help more
      • drp102
        • Apr 2014
        • 9
        • united states
        unplugging t-con board same thing two blinks
        • drp102
          • Apr 2014
          • 9
          • united states
          I know they are different way to put update firmware on the flash memory by a isp programer but has never done it in the past so not sure exactly how to do it
          • nuala
            • Aug 2013
            • 37
            Check or replace r6541/r6542 and r6537/r6538 all are 2meg 1/2 watt and 1 watt. This is for 2 blinks.
            • drp102
              • Apr 2014
              • 9
              • united states
              were do you see those resistor cause I looked every where and couldn't find it
              • drp102
                • Apr 2014
                • 9
                • united states
                I need to update my firmware has anyone here put new firmware on the flash memory thru a isp programmer if so let me know what kind of programmer you use and the accessories its not updating thru the usb stick
                • aaronwt6
                  • Apr 2013
                  • 855
                  • US
                  Not sure if Sony has this but on many Sharp sets you can hold down the power button for like 10 seconds and clear an overload fault.
                  • drp102
                    • Apr 2014
                    • 9
                    • united states
                    tried that it dosent work
                    • abdekader
                      • Jul 2014
                      • 73
                      • Turkey
                      I have the same problem , what's the solution for Main Power Over Voltage Protection?
                      Electronic Engineer from Syria,Aleppo
                        Service manuals:
                        http://elektrotanya.com/?q=showresul...at2=schematics
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
                        • jb_Bak
                          by jb_Bak
                          CN6401
                          Pin 01 NC
                          Pin 02 NC
                          Pin 03 "BL_ON": 0V
                          Pin 04 "N/C"
                          Pin 05 "STBY 3.3V": 3.5V
                          Pin 06 "GND": N/C
                          Pin 07 "AC_OFF"...
                          09-27-2021, 04:52 PM
                        • howardc64
                          by howardc64
                          07-24-2025, 05:17 PM
                        • delpiero3
                          Sony Vaio SVS MBX-261 board failure
                          by delpiero3
                          Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                          Nevertheless, let's say, i don't come as a total beginner.
                          I have this old laptop, which suit perfectly my needs, with the...
                          10-29-2024, 06:16 AM
