Philips 19PFL4505D Turn On Byself
  • crdz66
    • Nov 2012
    • 242
    Hi Everyone.
    Can somebody tell me what is the most cause for a lcd tv turn off by self after 30 minutes or sometimes running.?
    No timer set, input connected.
    • 31196
    Re: Philips 19PFL4505D Turn On Byself
    no.
    too many possibility's
    you need to get the back open and take foto's of the boards - both sides.
    • crdz66
      • Nov 2012
      • 242
      ok. I will
      • JorKsX
        Philips 47pfl6008s wont turn on
        by JorKsX
        Hello. Got my hands on Philips 47pfl6008s/12.
        Problem is that it does not turn on. Last owner said the problem came slowly.
        One day did not respond to remote, had to unplug from AC and then back and it worked. next day had to disconnect 3-4 times before it turned on.
        And then it went into hours of unplugging and replugging until it turned on.
        When I plug AC into tv, it does not respond to "turn on" button or anything else.
        After 10-15minutes the TV starts blinking red LED twice.
        So it blinks twice, then waits 3 seconds, then again twice...
        02-13-2022, 03:36 PM
      • pajdek
        Lenovo Y700-17ISK turn on and off
        by pajdek
        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
        09-20-2023, 02:49 AM
      • ovrax
        Philips 55PUS6804/12 turn on & off (probably backlight issue)
        by ovrax
        First of all, please excuse me as I'm quite new to this field.
        I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
        I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
        The Ambilight works perfectly and stays on.
        No sounds.
        Thanks in advance.
        08-25-2024, 04:33 AM
      • RdeveLabs
        MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
        by RdeveLabs
        To all the members here...
        Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
        So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
        05-05-2025, 04:59 AM
      • robante15
        Acer Aspire 4520 won't turn on after reboot
        by robante15
        Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
        It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
        The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
        If I remove the...
        04-06-2024, 06:50 PM
