Philips 47PFL7642D/12
  • thejay
    • Mar 2014
    • 12
    I've turned on a Philips 47PFL7642D/12 LCD TV after about a year.
    Screen stays black, no backlight, no sound. Power-on-LED turns blue as expected.
    I already replaced the four caps on the two inverter boards as they looked vented. The only fuse I found is on the power supply board and is ok.
    Where to begin?
    Re: Philips 47PFL7642D/12
    Are you getting 24VDC on both ends of that white fuse (chassis as GND ref for the meter) on the inverter boards? Do you also see if the backligts even flash on for seconds?
    • selldoor
      Slow Learner
      • 7870
      Give it a good dusting - brush and vacuum should do it.
      Was it working before it went into storage
      • thejay
        • Mar 2014
        • 12
        Thanks for all replies so far!
        @budm: Forgot my meter at work, can't do it before tomorrow.
        @selldoor: Yes, it worked before. But I guess it was already dusty back then :-)
        (I'll clean it nevertheless and give it a try)
        @all: Nobody noticed the cap I've resoldered with reversed polarity yet? Unfortunately it wasn't the cause either.
        • selldoor
          Slow Learner
          • 7870
          If you switched it on with the cap reversed you should consider changing it again.
          • thejay
            • Mar 2014
            • 12
            Don't worry, I used a new one
            • thejay
              • Mar 2014
              • 12
              @budm: I get a 0V reading on both ends of both fuses. Backlight stays completely off.
              So I guess the problem is rather on the power supply side?
              • selldoor
                Slow Learner
                • 7870
                Maybe , maybe not. try unplugging replugging all the connectors a few times to clean off any oxidation then with it all plugged in and connected up test all the pins on all the connectors post results like
                CN?
                pin 1....12v....11.99v
                pin 2.... 5v.....2.48v and so on
                on connector cn 7 there is a pin PSON can you use meter on vdc20 and monitor what happens on that pin from plug in to switch on to fault position.
                • truep
                  • Aug 2010
                  • 373
                  Also check the caps under the power supply heat sinks. The engineer(?) that designed that should be fired!
                  • thejay
                    • Mar 2014
                    • 12
                    Heureka! Found one obviously vented cap right below the large heatsink. Replaced it and everything works fine now.
                    Final question: Does it make sense to replace the remaining three old caps as a precautionary measure? I ask because this will be rather complex. They really managed to solder the heatsink to the board!
                    • corrize
                      A funny fuse story – Lumix LX100 II
                      by corrize
                      Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                      I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                      The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                      There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                      And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                      10-19-2023, 09:58 AM
                    • eccerr0r
                      inverter H tree driver imbalance in an AC inverter
                      by eccerr0r
                      My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                      Yesterday, 12:34 PM
                    • jesterace
                      Samsung UE46ES8000 Blown fuse but no other signs of short
                      by jesterace
                      Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                      09-11-2024, 03:14 PM
                    • jshhh
                      Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                      by jshhh
                      Hi guys,
                      I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                      How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                      Anybody know how to remove this type of fuse?
                      (The fuse is toward the bottom of the image labeled F2)...
                      06-17-2025, 01:35 AM
                    • Babbar
                      by Babbar
                      04-12-2024, 01:12 AM
