Techwood 37722HD after PSU change still have no backlight
  • stevegym
    • Jul 2014
    • 7
    I have this LCD. Before the power board change, it was not turned on at all. I changed the PSU for a good one, and the symptome is the next: When the tellie turns on, we have a picture just for 1 sec, then the backlight turns off, but you can see the LCD picture from very close, so this means probably the inverter board or the ccfl is the fault. I guess for the inverter.
    Have anybody a schematic for this tv or any idea what else can I check.
    I will upload a few pictures soon.
    Thank in advance for any idea!
  • selldoor
    Slow Learner
    • 7870
    Re: Techwood 37722HD after PSU change still have no backlight
    Could be inverter or backlights or even mainboard problem or even the new psu
    without further tests it is not possible to tell.
    If you have a problem with pictures they need to be jpgs less then 3mb
    you can post them using manage attachments.
      I have encountered bad inverter transformer on this model before, easy fix. As selldoor says, pictures please.
      • stevegym
        • Jul 2014
        • 7
        There you go. These are from the Inverter. Do we need any more picture from any part?
          Famous DARFON transformer, check all the transformers
          Check the transformer windings resistance between: make sure to report if the reading is shown in OHM, K OHM, or M OHM.
          pin 1 & 8 = xxx OHMS
          pin 4 & 5 = xxx OHMS
          pin 5 & 8 = xxx OHMS
          • stevegym
            • Jul 2014
            • 7
            These are the boards. This is a new PSU on the picture what I bought actually on ebay from a good seller. It was tested.
            Thanks in advance for any idea!
            • stevegym
              • Jul 2014
              • 7
              Ok. Give me a few minutes
              • stevegym
                • Jul 2014
                • 7
                pin 1&8= 2,2 Kohms
                pin 4&5= 2,2 KOhms but there was 1 transformer where 2,0 KOhms ( I guess it is fine)
                pin 5&8= 5,3 KOhms there was one where I measured 5,0 KOhms
                  Around here we figure that it should be within +/-3% from each other, so the 2.2K Ohms +/-3% will be 2266 Ohms on the plus 3% side, 2134 Ohms on the minus 3% side.
                  I would remove that one with 2K and inspect it closely.
                  • stevegym
                    • Jul 2014
                    • 7
                    Ok. I will doublecheck, but there was 3 what have 8-10% from the others. Is it too much difference do you think?
                    • selldoor
                      Slow Learner
                      • 7870
                      Unusual to have so many "off" ones what is the part number on them?
                      Is it one of these http://lcdparts.net/TransformerDetai...ProductID=3269
                      Perhaps retest just across S1 to S2 and S3 to S4 as mentioned Give result in ohms
                      as you now know 10ohms can make a difference.
                      make sure you are getting down to solder on the joints they are sometimes lacquered
                      Is the battery good in your meter?
                      The board pic doesnt really show enough - ideally we need the whole board even if its in a few shots
                      Straight on without flash. I can see 1 fuse but there may be more - can you test those as well.
                      • triplefour
                        by triplefour
                        09-13-2023, 10:43 PM
                      • DanPoka
                        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                        by DanPoka
                        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                        02-15-2025, 05:05 AM
                      • Comp_Pro
                        No Backlight Macbook A1990 820-01041
                        by Comp_Pro
                        Hello all,
                        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                        Tests performed:
                        There is no backlight even with a good screen.
                        Backlight IC is receiving the correct support voltages.
                        Fuse F8400 ok
                        Current sense resistor R8400 ok
                        Backlight IC is receiving 3.3V on enable pin.
                        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                        Backlight IC receiving 5V from PP5V_G3S
                        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                        05-06-2024, 10:23 PM
                      • jimbofz
                        lg 32LC46 backlight inverter board fault
                        by jimbofz
                        Hi this oldie had no backlight .after replacing caps on 24v rail ,
                        still no b/l this uses inverter type:1315 B1-16A,
                        im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                        all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                        this allows protect to be temporary overridden.
                        b/l now comes on
                        but the left hand side of pic is gradually darker than the right side
                        i have the cct for the tv
                        but it does not have inverter cct.
                        i opened it up to inspect the ccfl tubes
                        and they dont have any...
                        12-19-2021, 06:58 AM
                      • cheebster
                        iPad Pro 12.9 5th Gen Backlight Issue
                        by cheebster
                        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                        Anyone...
                        05-20-2025, 09:17 AM
