Samsung UN55C6400RFXZA Strobing flickering lines of dots on the display
  • Shinju
    • Mar 2014
    • 1239
    I am posting this for others to see since there is not any information on this unit here.
    I got this 55" for free the TV works but the display has dotted lines strobbing while the picture is displayed. They are really apparent on black scenes and not so much on brighter scenes.
    These dotted lines do not bleed or have the melting effect/ghosting.
    I am 90% sure this is a bad panel, I even broke it down to the tab bond level and applied pressure to them and this did not change how they acted.
    5% t-con 5% mainboard. Bummer too this was actually a nice panel for the time.
    Anyway here are some photos for future reference for folks who might encounter this problem.
    Also feel free to chime in if you might have some incite/input!
  • DemonBG
    • Mar 2012
    • 143
    Re: Samsung UN55C6400RFXZA Strobing flickering lines of dots on the display
    T-con failure - Had a UE40C6510 with an extremely similar fault today... (Although mine had nothing on the scnreen but the dots /lines where strobing on and off).
    T-con in my tv is a S120APM4C4LV0.4 too!
    Worth trying out
    Good luck,
    Demon
      You can access service menu and select test pattern options from it to confirm whether main board, t-con or panel are at fault. Given fault image, highly doubt panel is bad.
      • Shinju
        • Mar 2014
        • 1239
        I tried to access the get patterns in the SM and they wouldn't stay running it would fault back to the menu to access them.
        Maybe I far fingered the button, I will try again when I get back into town.
        • Shinju
          • Mar 2014
          • 1239
          @tom66
          Which test patterns determan what failure?
            What do you have available? Varies by model.
            • Shinju
              • Mar 2014
              • 1239
              So this is what I got, seems if I do READ_POST_PATT_SEL the test patterns are fine. The PRE_PATT_SEL the test patterns are affected with strobbing dots ect.
                How about afterDDR and beforeDDR FRCS patterns?
                • Shinju
                  • Mar 2014
                  • 1239
                  Nothing shows up on the screen for those. I had a hdmi signal playing in the background should I have not done that?
                  Before DDR 0/15 patterns displayed.
                  After DDR 0/8 patterns displayed.
                    You should get patterns. In my mind it is pointing to T-con fault.
                    • Shinju
                      • Mar 2014
                      • 1239
                      No patterns without a signal either, logic patterns don't show up as well.
                      What does t-con USB failure mean?
                      (not sure why these are showing up side ways when they are loaded up and displayed in the upload window normal.)
                      • Shinju
                        • Mar 2014
                        • 1239
                        Will any S120APM4C4LV0.4 t-con work I see quite a few for various panel sizes but the S120APM4C4LV0.4 is the same for this model and others as well.
                        Thanks guys!
                        • DemonBG
                          • Mar 2012
                          • 143
                          They are all the same and are used on multiple different panel sizes.... Good luck
                          • Shinju
                            • Mar 2014
                            • 1239
                            Thought so, just wanted to make sure, I know some T-cons actually have to match certain part numbers for example like LG ect.
                            Word, found one for cheap I hope it works!
                            Thanks DemonBG!
                            Tom66
                            I will update as soon as this part comes in and I get it installed.
                            Thanks to you both for the help!
                            • Shinju
                              • Mar 2014
                              • 1239
                              This one.
                              http://www.ebay.com/itm/171389750528...84.m1497.l2649
                              • DemonBG
                                • Mar 2012
                                • 143
                                looks about right! Good luck with the fix and hope it sorts you out!
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  So I was doing a little searching and it looks like the S120APM4C4LV0.4 3464E0 (bar code number) is the one for this panel.
                                  The one I ordered S120APM4C4LV0.4 3334J0.
                                  I will get it today so we shall see if it works :P
                                  • Shinju
                                    • Mar 2014
                                    • 1239
                                    T-con did not fix the flickering dots. Test more later but I assume it's a mainboard issue or panel.
                                    • Shinju
                                      • Mar 2014
                                      • 1239
                                      I also noticed that the Service menu under shop options has 3D options and 2 of them are turned on. I have not messed with them yet as I ran out of time last night.
                                      So I am at a loss what it would be, the test patterns tested the exact same as the previous T-con so its got to be the mainboard at this point or panel?
                                      • Shinju
                                        • Mar 2014
                                        • 1239
                                        Gonna try a different mainboard, BN94-03404K (its for a 46") should be able to adjust panel type ect.
                                        • reessi
                                          ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                          by reessi
                                          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                          They are black on the right and gradually fade to nothing on the far left.
                                          They start either after 5 mins or up to 2 hours after so annoying for testing.
                                          They flicker continuously very fast! With a slight pause milli-second every second.
                                          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                          I tested each half by removing the first the left flex from...
                                          06-03-2025, 09:58 AM
                                          09-07-2024, 05:50 AM
                                        • mrsith
                                          Samsung UE70TU7100 - flickering horizontal lines
                                          by mrsith
                                          Hello again good souls.
                                          Got an UE70TU7100. The TV starts up just fine, but right hand side of the screen is horizontal striped a bit, and there are some flickering horizontal lines on the whole length of the screen. I've seen similar static horizontal lines sometimes, when applying the cut tape method and covering wrong number of pins.
                                          I've cleaned every connector with ipa, tried cut tape method on main LVDS ribbon as well as small ribbons, connecting the panel boards at the bottom. Tried squeezing the bezel and playing around COFs, but no reaction at all. COFs and...
                                          02-13-2023, 05:36 AM
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          A similar issue has been posted as well but also with no actual response ...
                                          08-12-2025, 04:19 AM
                                        • Rubenlily
                                          Samsung QE50Q67TAU - horizontal lines
                                          by Rubenlily
                                          First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                          I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                          I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                          I'm no expert but I've done the tape...
                                          08-16-2023, 01:12 PM
