Samsung UN55C6400RFXZA Strobing flickering lines of dots on the display
  • Shinju
    • Mar 2014
    • 1239
    Re: Samsung UN55C6400RFXZA Strobing flickering lines of dots on the display
    Fixed, mainboard was the issue for me.
    I will post the massive list of compatible mainboards. There is a lot of them!
    • reessi
      ACER BM320 Monitor - Horizonal Flickering Lines After a While
      by reessi
      The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
      They are black on the right and gradually fade to nothing on the far left.
      They start either after 5 mins or up to 2 hours after so annoying for testing.
      They flicker continuously very fast! With a slight pause milli-second every second.
      Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
      I tested each half by removing the first the left flex from...
      06-03-2025, 09:58 AM
      09-07-2024, 05:50 AM
    • mrsith
      Samsung UE70TU7100 - flickering horizontal lines
      by mrsith
      Hello again good souls.
      Got an UE70TU7100. The TV starts up just fine, but right hand side of the screen is horizontal striped a bit, and there are some flickering horizontal lines on the whole length of the screen. I've seen similar static horizontal lines sometimes, when applying the cut tape method and covering wrong number of pins.
      I've cleaned every connector with ipa, tried cut tape method on main LVDS ribbon as well as small ribbons, connecting the panel boards at the bottom. Tried squeezing the bezel and playing around COFs, but no reaction at all. COFs and...
      02-13-2023, 05:36 AM
    • Rubenlily
      Samsung QE50Q67TAU - horizontal lines
      by Rubenlily
      First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
      I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
      I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
      I'm no expert but I've done the tape...
      08-16-2023, 01:12 PM
    • jeyoung12
      Samsung QN50Q60t lines on screen
      by jeyoung12
      Hi all
      I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
      My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
      This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
      It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
      So....i don't know what end of the C ribbon to work with...
      02-26-2024, 10:38 AM
