SONY KDL-46R473A ALMOST DEAD NO STB
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    Hello to everyone in this wonderful forum.
    I have this SONY LCD TV KDL_46R473a
    PSU GL5 APS350 :1-888-122- 12
    MAINBOARD FY13_EU IP-012C101-4010
    black screen ,no STB no life almost death.
    on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
    Also 3,5,and 12v are on.
    nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
    don't know what to do next all suggestions and advice are very welcome​
  • Diah
    • Feb 2013
    • 6498
    from yours description and messing , that you don't have front LED and no error code, the suspect here the SoC MT5367 which IR and Front LED supplied direct from it.
    however you have integrated T-CON on Panel, did you check the fuse on Panel Puffer boards close to the LVDS socket if it had 12V , in case yes... disconnect the U ribbon at panel from one side., one things more think about this TV from 2013 i just wounder too if the LED BL still survived until now
    • Diah
      • Feb 2013
      • 6498
      service manual
      • bohaboha
        • Nov 2012
        • 1017
        • sweden
        [QUOTE=Diah;n3622922]from yours description and messing , that you don't have front LED and no error code, the suspect here the SoC MT5367 which IR and Front LED supplied direct from it.
        however you have integrated T-CON on Panel, did you check the fuse on Panel Puffer boards close to the LVDS socket if it had 12V , in case yes... disconnect the U ribbon at panel from one side., one things more think about this TV from 2013 i just wounder too if the LED BL still survived until now[/
        Hi Diah on the whole Panel Ribbon it's 0V there is no power being delivered from the mainboard . but there is power on the Mainboard
        • Diah
          • Feb 2013
          • 6498
          this mean as i wrote before the SoC. MB need to replace... upload high resolution photo of yours MB from Top side Only... we may understand more this issue
          • bohaboha
            • Nov 2012
            • 1017
            • sweden
            here some ones hope it is ok
            • Diah
              • Feb 2013
              • 6498
              • bohaboha
                • Nov 2012
                • 1017
                • sweden
                Originally posted by Diah
                sorry have some internet problem . near CN201 there are 6 capacitors 3 of them pips short .
                • Diah
                  • Feb 2013
                  • 6498
                  if you mean closr to the downside of lvds socket they related to t-con 12v vcc
                  • lotas
                    • Jan 2016
                    • 4804
                    • Russia
                    Which?
                    • bohaboha
                      • Nov 2012
                      • 1017
                      • sweden
                      no it is exactly near the socket CN201 the right side there are 5 big and to small capacitors the 3 big ones under they bib on both sides
                      • bohaboha
                        • Nov 2012
                        • 1017
                        • sweden
                        Originally posted by lotas
                        Which?
                        the 3 big ones in row
                        • lotas
                          • Jan 2016
                          • 4804
                          • Russia
                          These? If yes, then this is already at the output of the dc/dc converter, the choke also has a short circuit between gnd, so we need to determine what is shorting, it could be the capacitors themselves and the converter or the chips that sit on this bus... What is the marking on this converter (8 pin.)?
                          • bohaboha
                            • Nov 2012
                            • 1017
                            • sweden
                            the converter Z1043P1 the second line ZS2321
                            • Diah
                              • Feb 2013
                              • 6498
                              Z never being converter .. its kinda like ESD diode for Data speed transfer protection
                              • lotas
                                • Jan 2016
                                • 4804
                                • Russia
                                Z1043P1 is the AOZ1043PI converter from Alpha and Omega Semiconductor, but I can't find the datasheet, is it from the AOZ1034 series...
                                • bohaboha
                                  • Nov 2012
                                  • 1017
                                  • sweden
                                  same here does not find Datasheet. shall i lift or take away one by one those capacitor to find the short ?
                                  • lotas
                                    • Jan 2016
                                    • 4804
                                    • Russia
                                    Well, if you are good at using a soldering station, you can try, first, under a strong magnifying glass, inspect these capacitors for cracks, small burnouts on them, if you find any, then this will be the culprit, if you don't see anything, then first remove the choke, this will determine whether the converter or the capacitors are short-circuiting....​
                                    • bohaboha
                                      • Nov 2012
                                      • 1017
                                      • sweden
                                      What is The choke? They look to be ok have already lifted the first closest socket 201 but nothing is happening still short. then i measured the chipset Z1043P1 and on the first pin the 1.84V + nearest SOC just to the left there are two small capacitor they are also shorted . but on the SOC itself in the first pin at the edges there is power at 2.584V
                                      • lotas
                                        • Jan 2016
                                        • 4804
                                        • Russia
                                        You don't know what a choke is? It says "2R2" (a coil wound on a ferrite core)!
                                        • thstuff
                                          Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                          by thstuff
                                          A) TV initially dead
                                          B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                          C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                          D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                          E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                          12-26-2024, 09:10 PM
                                        • jamesp
                                          Acer Aspire A315-55 Dead mainboard
                                          by jamesp
                                          Hello, can someone please help me. i have a dead laptop mainboard, aspire a315-55 with board model DA0ZAWMB8G0 rev. G
                                          upon checking of voltages at s5, 19v is present Vin, 5v and 3v is present at PL6001 and PL6000 respectively, but no signal from MAINON And s5_ON to be able to produce +3v_s5 to give power to vcc of BIOS CHIP U2. MAINON and S5_ON is coming from ec chip U37 it8987e/cx.
                                          do i need to reflash the EC? any advice? thanks...
                                          09-30-2024, 08:24 AM
                                        • 3mz3t
                                          ThinkPad T14 Gen1 Intel, dead mainboard
                                          by 3mz3t
                                          NM-C931 mainboard, does not start, no light, no nothing. Draws 20.56 V / 0.14 A from a wall charger.
                                          Under thermal camera, the only thing that show is the ThinkEngine chip (BD4179MWV / UTE1B) heating up (also quite hot to the touch), there's 19.75 V on the VREGIN20 (pin 45).
                                          Is the BD4179 dead? WDYT?
                                          Thank you....
                                          08-05-2024, 04:59 AM
                                        • Talyn
                                          Sony 55W905 dead
                                          by Talyn
                                          My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
                                          I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
                                          Any advice? Thanks!
                                          04-15-2024, 08:14 AM
                                        • mmartell
                                          Sony KDL-65W850C is this a Mainboard issue ??
                                          by mmartell
                                          This sat around for quite some time after the backlights died with the six blink error code. I bought replacement strips and eventually swapped them in.
                                          Backlights appear to be working fine now. However the tv only powers on with the "Sony" logo for about two seconds after which it goes away and the panel with backlights stay powered for about twenty more seconds then it shuts off. Tv can only be powered again after power cycling at the outlet.
                                          It will not program via usb, the stick flashes but there is never any indication that it has entered programming...
                                          11-19-2023, 10:27 AM
