hi all new to the forum, please tell me if i break any forum rules
. i have a technika lcd40-270 that turns on and off on its own for like 20 minutes until it eventually powers on and works perfectly until i turn it off, i purchased a used pcb off of ebay, which the tv just turns on and off but never turns on with the ebay bought pcb, the seller assures me it works, but i have read how terrible these board's are and in my mind if my pcb turns the tv on after 20 minutes and the ebay bought one doesnt turn on at all, the one he sent is faulty too, does this sound like a faulty pcb or could it be the main board? thanks in advance for any info/help
andy
Technika lcd40-270 pcb issues??
Re: Technika lcd40-270 pcb issues??
does sound like the ebay ones faulty, whats the part/model number from the power board? if you have a multimeter there maybe some tests we can help you do also if possible can you upload a clear picture of the psu so we can see what we are dealing with cheers. -
struggled getting pictures with phone, could possibly upload some better ones tomorrow, thanks for your reply and also my pcb is exactly the same but a couple of the solder joints are touching on the right hand side of the board under the connectors on the ebay one but on mine they aren't not sure if thats how its meant to be or not, thank youAttached Filesif you find these attachements useful please consider making a small donation to the site
can you show a picture of your board and then the ebay one so we can see what you mean cheersstruggled getting pictures with phone, could possibly upload some better ones tomorrow, thanks for your reply and also my pcb is exactly the same but a couple of the solder joints are touching on the right hand side of the board under the connectors on the ebay one but on mine they aren't not sure if thats how its meant to be or not, thank youComment
ill do it straight in the morning, the mrs is moaning as she wants to watch the tv and dont appreciate it being in bits lol, thanks for your help and sorry for the inconvenience, i apreciate your time and effort, thanksComment
try this with your working psu before you switch it on in the morning try heating the whole power supply up with a hair dryer for about 3 to 4 minutes also aim the air under the heat sinks onto the capactors under them it the tv now starts straight up ok theres a good chance its just a capacitor issue on your old but working psuComment
i tried it earlier on both psu's it certainly came on faster but still took time on mine, but it made no difference to the ebay one, but ill give it a go tomorrow because i didnt hold the heat on for aslong as that, cheersComment
To me that indicates a bad PSU... You could prob fix the original yourself. My guess - cold solder or bad startup capPlease do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
no the start up cap is usually a very little one in size when the lights good try to take a good clear picture and we will point it out but also try the hairdryer trick too as some times if a cap is bad heating it up will get the set working for fault finding purposes.Last edited by vinceroger69; 07-08-2014, 01:29 PM.Comment
sorry my post came up twice please ignoreLast edited by vinceroger69; 07-08-2014, 01:28 PM.Comment
Start up caps.Attached Filesif you find these attachements useful please consider making a small donation to the site
its definately the startup caps, it comes on about in about 2 minutes when i heat the 2 capacitors, iv resoldered them underneath, but still same reply, there 220uf 50v im trying to locate some panasonic ones but im worried about the size, will they all fit or do they differ in sizes, thanks for the help guys, this is genuinely the best forum ive come across in a long timeComment
Buy them from CPC. Free delivery. Don't risk it with eBay.
What values do you need?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Are they the only two small caps on the primary (HOT, AC) side of the power supply? Any other small ones in that region? Note, primary marked by the black boundary.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
It's probably best to replace all of them. You can bend the capacitor over to read the values, or desolder them.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by zlr8rhey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
Ill try and give as much info as I can.
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
When I received this , it would only flicker on the KB backlight for a second, then off and on.
Then it started getting weirder!
Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has... -
by StephenMacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
yesterday i bought this
I was not high on caffeine but the specs we nice-- Processor: AMD Ryzen 5 4600H 6 x 3 - 4 GHz, Renoir-H (Zen 2)
- Graphics adapter: AMD Radeon RX Vega 6 (Ryzen 4000/5000)
- Ram: 16gb DDR4
I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
Well, my decice specs are the following:
Model: Acer Nitro 5 AN517-54-55T5
CPU: Intel Core i5-11400H
GPU: NVIDIA GeForce GTX 1650
Motherboard: GH51G LA-L181P Rev:1c
The symptom:
When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...05-26-2025, 10:49 AM -
by wwwI am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....-
- Loading...
