Xbr-65A1E Sony OLED
  • EazyBone
    • Jun 2023
    • 1348
    • United states
    Xbr-65A1E Sony OLED
    Got this Sony. Wouldn't turn on. Wouldn't show indicator light. Checked PSU. Voltages seemed to be correct. Suspected main board EMMC. Pulled the chip off and it tested completely fine.. never put the chip back on. Friend had another board for this TV that he believed to be working. Plugged it in. Still nothing. No indication. Started probing around some more and found the main board has a connector going off to somewhere.. I can't see where as there is so much crap to take off (very weirdly designed tv) the connector has no markings for what it is. See video. I disconnect this connector and hit power and lo and behold I have sound and hear the tv. I test the points with and without connector and the voltage is fluctuating crazily.
    Any idea what may be causing this or more info I can show you to help figure it out.
    https://youtube.com/shorts/ZHNiMOF11...ZZ5cSjO9NPUKUB
  • EazyBone
    • Jun 2023
    • 1348
    • United states
    Oddly enough, the voltage still fluctuates but now the TV is nonstop blinking red/white. Not a number of blinks just continuously blinks. Suggestions?
    Edit... And now it turned on and still continues to blink red. Took a long time to turn on. Will update back
    • EazyBone
      • Jun 2023
      • 1348
      • United states
      Latest update. https://youtu.be/5Bti_Is_2Wo?feature=shared
      When I first lifted the TV these patterns were not there. Then I put the tv up and this shows up. That voltage on the main still fluctuates..
      Anyone know what this is?
      • EazyBone
        • Jun 2023
        • 1348
        • United states
        Was able to get to service menu.
        • nomoresonys
          • 12206
          • U.S.
          Will it allow a factory reset and software update? Sometimes the update will work for certain problems.
          • nomoresonys
            • 12206
            • U.S.
            Probably need to do an update/re-pair each time a mainboard is replaced.
            • EazyBone
              • Jun 2023
              • 1348
              • United states
              It stays on a random amount of time. One time I got it to software update through wifi. It updated and says no more updates. It also says it's a 55 board and I'm using a 65. I have updated before with USB and it works but it won't update at all through USB . And it keeps shutting off.
              • nomoresonys
                • 12206
                • U.S.
                maybe check the coils on the mainboard for the usual voltages 5, 3.3, 1.8 etc.
                • EazyBone
                  • Jun 2023
                  • 1348
                  • United states
                  I do have this also. Usbs also have 5v.
                  I haven't seen this very methodical green pattern and makes me think it's a component rather than the panel.. but shutting off makes me think that also. I just don't know. I always have bad bad luck with OLEDs. They seem to just die on me. Probably 50/50 with them
                    ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                    This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                    09-07-2024, 04:30 AM
                  • Tomylee
                    No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                    by Tomylee
                    Sorry for the person who’s going to read all this !
                    I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                    While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                    During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                    07-11-2025, 11:52 AM
                  • Glaval
                    Sony OLED XBR-65A8G 4 flashes
                    by Glaval
                    Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
                    01-23-2025, 04:04 PM
                    Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                    This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-07-2024, 07:12 AM
                    Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                    This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
