Philips LED tv 40"
  • ecu971
    • Jul 2014
    • Sverige
    Philips LED tv 40"
    Hi
    Its totally dead, no lights what so ever. Fuses are okey, nu bulbing caps or so. Got correct ac input. Have tested all components on heatsinks, fets, dual diods etc. I have not tested much on the small stuff on the underside. Some suggestions?
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Philips LED tv 40"
    post some pictures of front and back side of power supply....
    And MODEL NUMBER of TV...
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • MisterD
      • Oct 2012
      • 668
      Post pictures of circuit boards, check and record all voltages on rail connectors on the power supply board and take close up pictures of the connectors.
        If it totally dead and the main fuse is good, then you need to verify that you do have DC Voltage right at the two legs of the main filter cap, we need to have at least that voltage first before going further. Pictures of the board will help.
        • alro7779
          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
          by alro7779
          Hello, guys!
          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
          09-14-2025, 12:25 AM
        • G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
          by G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
          It does power up when pressing the power button.
          I already try the power button while plugin the plug with no result.
          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
          Could this be an PSU or eMMC issue ?
          07-19-2025, 03:43 AM
        • double_DD
          Philips curling iron - is this a common AC cable?
          by double_DD
          Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
          As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
          Not sure if this is something Philips proprietary, or a standard, but the cable plug...
          08-18-2025, 10:04 AM
        • janos6662000
          Philips 47PFS7509/12 LCD TV problem
          by janos6662000
          Hi
          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
          When i applied cable signal to check image, i had normal picture, but TV was restarting.
          I downloaded original firmware and applied the update, but the problem remained.
          From a colleague i received a "factory package software" which is a lot bigger.
          I made another firmware update, but still did not solve the problem.
          Somewhere on the way the error got worse, because at the moment the...
          08-12-2025, 12:54 PM
        • aidanmo
          Philips 43PUS7506/12 - Loud blown out sound
          by aidanmo
          I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
          I thought maybe the speakers got damaged, so I replaced them - no dice.
          • Using the internal speakers, it always happens.
          • Using the headphone jack, it never happens.
          • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
          02-28-2025, 03:13 PM
