Vizio VW42lfhdtv10a - No standby
  • uberdaan
    • Jul 2014
    • 16
    First post, so please be gentle
    I have a 42" Vizio LCD that doesn't consistently go into standby when you turn it "off". It usually goes from white light to no light (no orange light). In order to get the orange light working again, I have to unplug it for a few seconds and plug it back in. (EDIT: To be clear, the TV turns on and works normally when you reset it and have the orange light on).
    I took it apart to do some investigating (thanks badcaps!), and found the power board to have a very light humming/buzzing sound when the set is plugged in AND the orange light is on. I can't tell where on the power board the buzzing is coming from. When the orange light is off, there is only silence (and the TV cannot turn on).
    By this point, you might already suspect bad caps in the 5v rail. I thought the same, so I visually inspected the tops of every cap on the power board...no bulging/burning (see photos) or other obvious indicators (to me) of a bad cap. I'm not sure if its possible for another component (xformer/vreg) to cause this specific issue...so I'm kindly asking for your thoughts on the issue before I start replacing every cap on the board.
    Thanks for your input!
    Mainboard measurements are below, although I don't think the problem is on the mainboard (photos attached also).
    Fuses (each side):
    5.22v/5.19v
    12.27v/12.25v
    u16
    11.51v
    6.5mv
    5v
    u44
    8.41v
    9.67v
    11.52v
    u22
    2.09v
    3.3v
    5.2v
    u15
    2.08v
    3.3v (big tab...center pin is cut)
    5.16v
    u19
    1.2v
    2.5v (like u15)
    5.16v
    u17
    2.1v
    3.3
    5.16v
    u21
    5mv
    1.25v
    2.5v
    q19
    12.19v
    12.25v
    11.53v
    Power board output connector to mainboard (with tv on):
    >space
    >4.99v brown (B1)
    >3.36v black (A1)
    >5.23v white
    >5.23v gray
    >5.24v purple
    >(space)
    >0v blue
    >0v green
    >0v yellow
    >(space)
    >12.27v orange
    >12.27 red
    >12.27 brown
    >1.93v black (PSON)
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Vizio VW42lfhdtv10a - No standby
    To keep you busy till somebody smarter then me jumps in: When it's in failmode(no amber light) do you still have the 5v standby ?
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • uberdaan
      • Jul 2014
      • 16
      Ah - excellent question. I did check the voltages at the power board output in ON, OFF, and FAIL modes. The ON voltages are listed in my first post, but I didn't list the others.
      In the OFF mode (w/ orange light), there are a few mV on some of the pins.
      In the FAIL mode, there is 0v on all the pins. It's as if the main fuse blew - but I checked it, and the TV comes back on (I also replaced it anyway).
      I should also note that this seems to be an intermittent problem. It doesn't always fail hard - it does go into standby mode sometimes.
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        In standby WITH amber light you should have 5 volts standby....
        When amberlight is off and 5volt standby is zero,I would be curious to see if it comes back up by pulling connector to mainboard out...(to see if its the mainboard pulling 5volt down or if powerboard just fails)
        • uberdaan
          • Jul 2014
          • 16
          Interesting idea - I'll give it a shot.
          Is there a feedback circuit that would require the mainboard to be plugged in for the power board to output the voltages?
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            Yes and no. Power supply has a 5 volt life line that's always on so that the mainboards brain can function( standby light, remote function etc).
            Rest of power supply comes alive through a feed back from mainboard, backlight etc.
              May be you should read this:
              https://www.badcaps.net/forum/showthread.php?t=25810
              • uberdaan
                • Jul 2014
                • 16
                Thanks budm. I read the basic troubleshooting. The power board troubleshooting does apply. I measured the PS_ON output voltage with the TV on at 1.93v...does this sound like the correct voltage, or could it be just enough to get things going? (You quoted 3.3-5v in the tutorial).
                I measured everything I could coming off the mainboard - and all looks normal to me except U21. Problem is, I have no idea what u21 is supposed to do.
                I keep circling back to why this problem would be intermittent (and slightly noisy), unless it were a bad component (e.g., U21) in the 5v circuit. Wouldn't this failure mode cause the front standby light to die, and system to not turn on?
                  So, then when it is in failed mode, do you have the 5VSTANDBY or not? You can also tell if the PS_ON is high enough by measuring the DC Voltage RIGHT AT THE TWO LEGS OF THE MAIN filter cap (big blue cap laying on its side), it should have about 160~170VDC when TV is OFF and about 360~400VDC when TV is ON. See if that voltage also drops down to 170V when the TV failed.
                  • serious_electron
                    Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                    by serious_electron
                    Hello Everyone!
                    I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                    06-28-2025, 02:57 PM
                  • x_orange90_x
                    Vizio E550i-A0 no power, no standby light
                    by x_orange90_x
                    I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                    11-20-2023, 09:49 AM
                  • p-top
                    Vizio, E60u-D3, no standby light, no ps_on
                    by p-top
                    Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                    main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                    PS voltages
                    1 VSNS -2mV
                    2-5 LED-OUT -2mV
                    6-10 GND -2mV
                    11 +16VS 16.29V
                    12 AC-DET 3.929V
                    13PS-ON -3mV
                    14 +16VS 16.29V
                    15 +16VS 16.29V...
                    11-27-2023, 10:44 AM
                  • ChristianBr01
                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                    by ChristianBr01
                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                    04-23-2025, 01:48 AM
                  • mosfetratus
                    macbook A2918, orange light off when shut off
                    by mosfetratus
                    When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
                    Works with battery and charges, but when i shut off i get this problem.
                    It had liquid spill. Board has no corrosion, keyboard is working, power button...
                    05-31-2024, 03:34 AM
