samsung LN-T3253H no picture red standby light
  • jose6326
    • May 2013
    • 707
    Re: samsung LN-T3253H no picture red standby light
    Originally posted by budm
    OK, I will look at the SCH and see what they are per diagram, but I still need to see if the printing or color codes on the parts matched the diagram or not in case they have done some updates to the board you have. If you can read the printings on the part if they are not badly damaged, that will help.
    budm are you going to look at the schematic you provided?
    because it doesn't show too much of an actual part number?
    here are the numbers printed on the parts
    Pc803s - NEC 2561 WK727
    rm801- RESISTOR 4 color bands gold, silver, red, red
    cy803s - DA 102M DIC
    cm810 - B 222K 1KV
    cm801 - B H25 FQPF 9N50C
    cm802 - B H25 FQPF 9N50C
      Yes, its the value of the component as printed on the body.
      I.E. resistor RM801 in the SCH is 0.22 Ohm 1W Fusible resistor (FR)
      CY803 is the safety cap (x/y type) 0.001uf 400V X/Y safety cap.
      CM810 is 2.2nF (0.0022uF) 1KV Ceramic cap
      CM801 is 0.0033uF 100V, is this damaged by the glue?
      CM802 is 0.47uF 25V, is this damaged by the glue?
      PC803 Opto couple NEC P/N PS2561
      Can you please post the pictures of these parts?
      • jose6326
        • May 2013
        • 707
        budm
        cm801 & cm802 are the same mosfets with the same part numbers
        what you listed looks like capacitors
        I will post pics in a few minutes
        thanks
        • jose6326
          • May 2013
          • 707
          Here are the pics of the components
          I damaged one of the mosfets when I was trying to pry it off the heat sink
            CM801, 802 are the cap as shown in the SCH. May be you mean QM801, 802 in the SCh which are MOSFET FQPF9N50C.
            The cap DA102M does not look like it is damaged, check and see if it shows any leakage resistance.
            • jose6326
              • May 2013
              • 707
              When i get home i will check the board
              more then likely you are correct
              • jose6326
                • May 2013
                • 707
                You are right budm
                Qm801
                QN802
                These are the correct designations
                Cap DA102M reads "OFL" when I set my meter to ohms
                • jose6326
                  • May 2013
                  • 707
                  So is cap DA102M good if I am getting an OFL reading?
                  • jose6326
                    • May 2013
                    • 707
                    So what parts should I order?
                    I cant find the blue caps on digikey
                      CY803 cap is fine, the TV will still function without that cap installed.
                      The CM810 2.2nF 1KV: you can get that from Digikey or Mouser:
                      http://www.digikey.com/product-searc...5-R3AD222KANRA
                      http://www.mouser.com/ProductDetail/...h2U8rjWYxjc%3d
                      • jose6326
                        • May 2013
                        • 707
                        Thanks budm
                        What about the mosfet I damaged
                        I broke a piece of the plastic
                        It should be fine right?
                        Or should I order a new one?
                          I would order them and use them just in case. You should also order this cap which is a commonly failed cap CM808 (BLUE RECTANGULAR CAP). 0.022uF 1.25KV.
                          http://www.digikey.com/product-detai...1360-ND/592936
                          • jose6326
                            • May 2013
                            • 707
                            the tv works
                            I was worried at first for a few reasons
                            i forgot to order the opto couple but luckily it wasn't shorted
                            when i was installing the resistor part of the trace lifted when i pusted the lead legs of the resistor through the hole. once i soldered it in it was still kind of lifted from the board but the tv works perfectly
                            and i was so in hurry to install the components i forgot to install the "commonly failed cap CM808 (BLUE RECTANGULAR CAP). 0.022uF 1.25KV" that you suggested me to replace.
                            so now i have a spare
                            thanks Budm for all the help
                            now on to the next tv for repair
                            • ikeoyou
                              • Oct 2014
                              • 22
                              I am also having this problem with the same power supply board in the same television. There is no picture when plugged in, the red light blinks intermittently, and the bottom blue ambient light also flashes.There is no sound from the speakers. Also, I can hear a humming/high pitch noise coming from something on the board as if trying to start but failing. I have already replaced the 7 capacitors on the cold side with Rubycon ones with no luck. I'm currently in the process of cleaning up all the yellow glue and finding other failed components. I've taken some pictures of the other components that might need to be replaced. The black circular thing, not sure what it is, labeled 'NT8119' has corrosion under the glue that I removed. The other thing that may be replaced is the CM810 cap which also was corroded under the glue. Are there any other components that I should be inspecting? Also, to anybody who owns this tv, could you please tell me the size and length of the 15 housing screws, and the 4 screws for the power supply? I received this TV sans screws.
                              • ikeoyou
                                • Oct 2014
                                • 22
                                Sorry, Im not sure how to edit posts on here, but the black component should be NT811S, not NT8119.
                                • ikeoyou
                                  • Oct 2014
                                  • 22
                                  Update, after replacing only the resistor RM801 and capacitor CM810, the tv works again. Glad I stumbled upon this forum and thread.
                                    @ikeoyou: Glad to hear that it is fixed and thanks for the repair follow-up.
                                    • hapollo
                                      • 15
                                      I just picked up one of these as well. Opened the TV to find the glue all dissolved on several parts as well. No exploded parts or scorch marks like jose6326 though.
                                      Going to start with replacing resistor RM801 and capacitor CM810 as above and then take it from there.
                                      So why do they put glue on so many parts on this particular board? I have not seen such issues on other Samsung boards aside from bulging inferior caps.
                                      Do the glues serve a purpose when the soldered leads should be enough to keep the part in place?
                                        The glue is used to keep the parts in place during the wave soldering phase, and also for holding parts in place during transportation, but unluckily they use bad glue.
                                        • hapollo
                                          • 15
                                          Thanks budm. So no need to re-glue after I clean it? Attaching pics for those curious
                                          • slimsoul
                                            Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
                                            by slimsoul
                                            Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
                                            I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
                                            I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
                                            The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
                                            03-12-2024, 03:55 AM
                                          • marcinq
                                            Samsung UE60KS7000 No Standby Light
                                            by marcinq
                                            I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                                            I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                                            05-26-2025, 11:36 AM
                                          • SJX1290
                                            No Standby Light on Samsung SAMSUNG UE65NU7022
                                            by SJX1290
                                            I have Samsung UN65MU6300FXZA with Mainboard BN41-02662A, dead , No Standby Light. I suspect result of main power jumping. Checked all voltages on main board ok,..
                                            My main suspect is bad flash memory, ...
                                            Any suggestions or can someone please​ check dump file, in the attachment
                                            Thank you...
                                            09-07-2024, 01:35 AM
                                          • Jovica123
                                            Samsung UE55AU8072U no standby light
                                            by Jovica123
                                            i have here Samsung UE55AU8072U no standby light.
                                            Panel model : CY-SA055HGXY1V
                                            Motheboard model : bn41-02844A bn94-16868V
                                            When i press the power button,standby light turn on,after i release it immediately turns off.
                                            Unplugged main board from power supply - BACKLIGHTS COME ON.
                                            I think the motheboard is problem.
                                            I fixed two TV with same mistake,but they were 6000-series,there was a problem with the contents of the w25q40 chip.
                                            Here are all dumps : ic801(24c512),ic1603 and ic1604(25q40)....
                                            12-10-2023, 09:21 AM
                                          • ctroxtell
                                            Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                                            by ctroxtell
                                            I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                                            01-03-2025, 08:57 PM
