samsung LN-T3253H no picture red standby light
  • inline79
    • May 2012
    • 31
    Re: samsung LN-T3253H no picture red standby light
    Sorry to bring up dead threads but I thought it useful as this is a top search thread for this TV model so we keep things in one place.
    I had this TV given to me with the blinking red standby light.
    The glue looked bad and there was some corrosion on the legs of RM801 RM810 so I went ahead and replaced them and scraped the glue away - no change.
    Then I went ahead and replaced the 7 cold side caps as they are over 10yrs old. Still no luck.
    The board is making a zzzt-zzzt-zzzt, suggesting something still not right on the output side. There is 300-400V at RM801 so I guess the PFC stage is OK. Everything checks out visually. I've scraped away most of the remaining glue. What next? Check semiconductors?
      Lets us see the pictures of your board.
      • inline79
        • May 2012
        • 31
        Thanks for the reply. Here's some pics of my poor removal of glue. But I think I managed to get it away from all leads. I'm concerned that zener ZDTM851 (left of conn CM803 in the pic, had glue over all legs. I will try to test it.
        I had a 5W 0.22R in my drawer so I used that instead. Should be Ok to replace the 1kW RM801.
        • slimsoul
          Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
          by slimsoul
          Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
          I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
          I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
          The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
          03-12-2024, 03:55 AM
        • marcinq
          Samsung UE60KS7000 No Standby Light
          by marcinq
          I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
          I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
          05-26-2025, 11:36 AM
        • SJX1290
          No Standby Light on Samsung SAMSUNG UE65NU7022
          by SJX1290
          I have Samsung UN65MU6300FXZA with Mainboard BN41-02662A, dead , No Standby Light. I suspect result of main power jumping. Checked all voltages on main board ok,..
          My main suspect is bad flash memory, ...
          Any suggestions or can someone please​ check dump file, in the attachment
          Thank you...
          09-07-2024, 01:35 AM
        • Jovica123
          Samsung UE55AU8072U no standby light
          by Jovica123
          i have here Samsung UE55AU8072U no standby light.
          Panel model : CY-SA055HGXY1V
          Motheboard model : bn41-02844A bn94-16868V
          When i press the power button,standby light turn on,after i release it immediately turns off.
          Unplugged main board from power supply - BACKLIGHTS COME ON.
          I think the motheboard is problem.
          I fixed two TV with same mistake,but they were 6000-series,there was a problem with the contents of the w25q40 chip.
          Here are all dumps : ic801(24c512),ic1603 and ic1604(25q40)....
          12-10-2023, 09:21 AM
        • ctroxtell
          Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
          by ctroxtell
          I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
          01-03-2025, 08:57 PM
