samsung LN-T3253H no picture red standby light
  • slimsoul
    Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
    by slimsoul
    Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
    I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
    I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
    The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
    03-12-2024, 03:55 AM
  • marcinq
    Samsung UE60KS7000 No Standby Light
    by marcinq
    I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
    I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
    05-26-2025, 11:36 AM
  • SJX1290
    No Standby Light on Samsung SAMSUNG UE65NU7022
    by SJX1290
    I have Samsung UN65MU6300FXZA with Mainboard BN41-02662A, dead , No Standby Light. I suspect result of main power jumping. Checked all voltages on main board ok,..
    My main suspect is bad flash memory, ...
    Any suggestions or can someone please​ check dump file, in the attachment
    Thank you...
    09-07-2024, 01:35 AM
  • Jovica123
    Samsung UE55AU8072U no standby light
    by Jovica123
    i have here Samsung UE55AU8072U no standby light.
    Panel model : CY-SA055HGXY1V
    Motheboard model : bn41-02844A bn94-16868V
    When i press the power button,standby light turn on,after i release it immediately turns off.
    Unplugged main board from power supply - BACKLIGHTS COME ON.
    I think the motheboard is problem.
    I fixed two TV with same mistake,but they were 6000-series,there was a problem with the contents of the w25q40 chip.
    Here are all dumps : ic801(24c512),ic1603 and ic1604(25q40)....
    12-10-2023, 09:21 AM
  • ctroxtell
    Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
    by ctroxtell
    I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
    01-03-2025, 08:57 PM
