LG 50PS3000 garbage find
    My best garbage find yet.
    LG 50PS3000 with intact screen. (50" 1080p 2009 plasma panel.) Back cover was present but ALL screws missing so guessing someone had a fiddle. All boards in the set though and all cables hooked up. Minor damage to main board speaker cable but looks repairable.
    Found PSU fuse missing but couldn't find any shorts on the PSU so presume this was a diagnosis step but forgotten about by someone. Think set might have had the common pink tint issue as found two shorted FETs on Z-sustain near Vzbias generate & bias ckt. Since fuse on Z-sustain was OK & Vzbias regulator FET was OK, I suspect the shorts could have made PSU cycle on and off (the regulator FET would not have any current limiting.)
    Will replace Q13,Q14 & Q15, plus PSU fuse and with any luck it should work. There is always the chance of bad panel due to vertical line on these but usually it is minor and I'm not complaining for a freebie.
  • Shinju
    • Mar 2014
    • 1239
    Re: LG 50PS3000 garbage find
    Free is good!
    • jose6326
      • May 2013
      • 707
      free is always good
      • Shinju
        • Mar 2014
        • 1239
        My latest free ended up having a cracked screen, BUT good parts!
        Samsung LNT4665FX/XXA
          Lamp tester on PSU appears to indicate the PSU is OK. Need to get a new fuse to be certain but it looks good so far.
          • ecking767
            • Oct 2009
            • 492
            2009 model nice find !! I haven't found any TVs lately by my job dumpster, but someone brought a new Samsung 55" LED HDTV and they threw out the box leaving the stand & base with the mounting screws inside the box. easy sale!!
            good luck with the repair !!
              Got some fuses. Fired it up and I get a red picture, just as expected. (Z-sustain unplugged.) Great! I just need to repair the Z-sustain and it'll be perfect. No stuck lines on panel.
                FETs in and picture looks great!
                However the Vzb measures 135V (should be 97V) and will not adjust. Think I may have to replace other FET too... Result is a good picture but dark areas have sparklies - will have to see why the Vzb is too high.
                Still, panel looks good even with mild sparklies.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  Awesome
                  • 9302z28ss
                    • Jul 2014
                    • 57
                    • united states
                    youre pretty good at this tom, maybe you can help me figure out my issue with my panisonic tc-p42s30 power LED comes on i hear two clicks it shuts off then 15 sec one more click, no idea what to try here sorry to hijack
                      Please keep questions in your thread, tw2005 is helping you right now, no point in me joining in.
                      Pulled the regulation transistor... this is a little odd... it tests OK on my transistor tester, but from drain to source (fwd biased) on my meter I get about 5.5kohm which is a little unusual. Seems like it might be breaking down under load. I will replace it, cheap part. FQFP51N25.
                      • senndogg
                        • Dec 2011
                        • 383
                        • Albania
                        Good luck with that! seems that the entire zsus is £49 on ebay. anyway which are easier to troubleshoot and repair, the boards with individual transistors or the ones with hybrids?
                          By a factor of about 10x the ones with individual transistors are easier (like this one), and they are also more repairable!
                            Fixed! It was that FET. Even if it tests good in almost every way, it can be failed!
                            Clues for failure: Drain of FET was at 195V (Vs) and its purpose is to linear regulate the Vzbias supply, about 100V. The Vzbias actually measured 130V and as the set ran and warmed up, it creeped up to 150V, causing a very maldischarged image with high image retention and sparklies - bright images OK though. The source of the FET measured 130V-150V as expected (linear regulator) wrt to GND, but the gate ALSO measured the same, which indicates the control circuit was pulling gate LOW but FET was not acknowledging this "command".
                            Components replaced:
                            Q13,Q14,Q15
                            ZD902
                            R407,R408
                            Total cost = £13, TV was free.
                            Amazing what people will get rid of.
                            • Shinju
                              • Mar 2014
                              • 1239
                              Awesome!
                              Just wish all of them can be this easy
                                Don't like the LCD-like black level on this panel :/
                                Tweaked it:
                                -Vy to -170V (from -180V)
                                Vzbias to 80V (from 97V)
                                Set-UP turned down so ramp does not reach full Vs, verified using scope
                                Set-DN adjusted til maldischarge, then added a little extra margin
                                Vs/Va/Vsc not touched
                                It looks PZ80-like now - not fantastic but far, far better!
                                • thuss
                                  • Jul 2012
                                  • 317
                                  Hi Tom66
                                  Ive got the same set but the fuse is blown on the z sus is there a repair kit for that? I cant find one
                                  (or if anybody could hep)
                                  thanks in advance
                                    There are repair kits on eBay about £25 which is a good price considering all the parts involved, in most cases it's just those three transistors and some resistors that fail.
                                    • mwalsh
                                      • May 2006
                                      • 21
                                      How do you go about rain soaked bin finds in the UK? We don't get much rain in this part of the Americas (and it's getting to be less each year!), but I do tend to avoid dumpster diving in the days following a rain storm, because I don't want to bother tearing a set apart and drying it all out first before I can even try to fire it up and see what might be wrong.
                                      • drgears
                                        • Oct 2010
                                        • 25
                                        If you want more sets to play with,,,,,I have an ad running on craig's list that nets me a set or two ,,,getting tougher though ,,,more people getting into trying to repair or harvest parts for cash,,but will help you get more "stuff" to play with...Can you ever have enough broken TV's ??????
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • corrize
                                          Where to find a very small fpc connector 0.3mm between 2 pins ?
                                          by corrize
                                          Hello, I search this connector (oxydated).
                                          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                          Do you know how to find this connector please ? What is the exact name for find it ?
                                          08-06-2024, 05:25 PM
                                          Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                                          by sam_sam_sam
                                          This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                                          Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                                          07-07-2024, 02:34 PM
                                        • temyth
                                          Sentey ATX PSU - ERP650-PS - Trying to find out the right Standby IC
                                          by temyth
                                          Greetings! I have this ERP650-PS atx power supply, it is a relatively simple psu, the primary has a driver IC that controls the two main mosfets (two 20n60S5), together with a Classic Standby circuit with a PWM IC (not a FET like the VIper22A) , relatively similar to the SDC606P.
                                          The whole point is that I got this power supply years ago when I had no knowledge, apparently the PWM IC was burned because someone turned the power supply on with the switch at 110v in a 220v network (classic error). Important detail: the power supply at the time came without the primary capacitors.
                                          01-07-2024, 04:50 PM
                                        • PizzaMan
                                          Macbook Air A2681 logic board, find this part
                                          by PizzaMan
                                          I am trying to find this part on the logic board. See pictures below. It might be CR812, not sure. Any help would be appreciated. And where could I find the part?
                                          05-24-2025, 12:34 PM
