LG OLE65C1 Stand-By issue
This topic has been answered.
  • Titus6
    • Jan 2025
    • 15
    • Hungary
    So I had the time to take my TV apart again. I soldered out C601 capacitor. I measured it. It was 720nF instead of 820nF. I ordered the spare parts but unfortunately I didn't get them yet, I was just curious how bad they are. As far as I understand these capacitors are for interference filtering. Do they really influence the power supply of the TV?
    Another note: Sometimes my TV's LED turns off and only comes baxk, if I unplug it from the wall for a few minutes. Does it make the capacitors more suspicious?
    Thanks for the answer!
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4316
      • Italy - Milan
      remove the comma... :-)
      820nF minus 20% of tolerance is less than 720nF, so i think the problem is not there.. a filter is important when the input is dirt, when it is not i guess is irrelevant for the set, if
      • Nousernameavailable
        • May 2025
        • 5
        • United Kingdom
        Hi Titus6, did you ever find the faulty cap?
        • Titus6
          • Jan 2025
          • 15
          • Hungary
          Hi Nousernameavailable!
          No I didn’t. Right now I’m just dealing with my TV as it is. Still working, sometimes I have to
          unplug it from wall socket and connect it again.
          I spoke with a local LG service not far from me, but I didn’t take my TV to them yet. They said in the phone that according to my symptoms they guess my Main Board is the problem, but they have to investigate it in person. Unfortunately they don’t come to my house, I have to deliver my TV to the service. Since it’s a pain in the ass I only take the TV to them if my symptomps getting worse.
          Long story short, no solution yet
            • May 2025
            • 5
            • United Kingdom
            No I didn't. Right now I'm just dealing with my TV as it is. Still working, sometimes I have to
            I spoke with a local LG service not far from me, but I didn't take my TV to them yet. They said in the phone that according to my symptoms they guess my Main Board is the problem, but they have to investigate it in person. Unfortunately they don't come to my house, I have to deliver my TV to the service. Since it's a pain in the ass I only take the TV to them if my symptomps getting worse.
            Ok thanks for the reply anyway. I found some more info in another (German) forum https://www.repdata.de/wbb2/forum/in...t-das-netzteil
            I'm going to try replacing C601 + C602 with Würth 890324025047CS.
              • May 2025
              • 5
              • United Kingdom
              #26
              I changed the caps and all is well again 👍
              • Diah
                • Feb 2013
                • 6363
                why you linked external answer and in this threat the answer was there post #3 ?!
                  • May 2025
                  • 5
                  • United Kingdom
                  #28
                  My bad, I read so many posts I lost track
                  • Titus6
                    • Jan 2025
                    • 15
                    • Hungary
                    #29
                    Thank you for letting us know your results. As Diah mentioned he already suggested this solution in this thread. I also ordered the same Würth cap and I will try it as well.
                    Hope it solve my issue too.
                    • Titus6
                      • Jan 2025
                      • 15
                      • Hungary
                      #30
                      Hello guys. Finally the caps arrived and I changed them, and... half a year of stress and anxiety is gone finally. I can say that after two days of testing my problem is REALLY SOLVED. The Stand-by LED is always on. My TV was able to do the Pixel refreshing again.
                      I can't thank you enough you guys for sharing your knowledge with us.
                      Diah Your post was really the solution, I set it as the answer. Thank you for your effort, you're truly amazing.
                      Nousernameavailable Thank you for sharing the exact type of the cap (Würth 890324025047CS) what I need for the repair. Actually you gave my motivation back, when you wrote down the exact type of the cap.
                      Also one added note:
                      I checked the Power On/Off Status with the service remote. There are no more entries of I took a picture of the entries OFF_BY_EDID_WRITE and ON_BY_LAST_WARM. So this problem solved as well, now I know it wasn't normal to see these entries.
                      So guys, you are awesome and I hope this conversation will help others with the same problem.
                        • May 2025
                        • 5
                        • United Kingdom
                        #31
                        That's great, glad to hear yours is repaired too!
                          • 12145
                          • U.S.
                          #32
                          Well done Diah, you solved it with one post.
                          • proditaki
                            JBL ES-150-P standby issue
                            by proditaki
                            I recently bought a faulty JBL ES-150P subwoofer that was completely dead.
                            After replacing 2 open resistors (R255 and R256) in the DC Power supply the unit started working.
                            It plays fine. But when it wants to go into standby mode, after 10 minutes, it starts cycling for a while. (see video on youtube)
                            The noise from the speaker goes away and i'm pretty sure the interval changes and i only hear one relay clicking on the end (light still goes red/green)
                            After cycling for like 30 secs to a minute it eventually goes into standby....
                            08-31-2023, 04:15 AM
                          • mecha1166
                            QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
                            by mecha1166
                            I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
                            03-28-2024, 08:31 AM
                          • rounin
                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                            by rounin
                            🛠 Original Issue
                            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                            04-19-2025, 01:18 AM
                          • ugamazing
                            by ugamazing
                            12-17-2024, 07:05 PM
                          • elmark
                            HP 15-cw1002ua strange keyboard issue
                            by elmark
                            HP Pavilion 15-CW1002UA
                            S/N 5CD0251CBC
                            P/N 7KE54EA
                            Hello guys!
                            I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                            It powers on OK and has no other issues except the following:
                            • CAPS LOCK does not work at all
                            • Fn button toggles Flight Mode
                            • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                            • (with SHIFT pressed: 't%' and 'y^' respectively)
                            I initially thought it was a keyboard malfunction (internal short, etc.),
                            but when I press and hold...
                            06-27-2025, 01:10 AM
